Ok, so I’m new to PlatformIO. I was getting very excited, started building out blink programs for all the various microcontrollers I have. Everything was going well. Then I started to migrate a project I am currently working on and it is encountering different behavior when compiled and pushed using PlatformIO vs Arduino IDE. It is a relatively simple light sequencer that uses the Adafruit NeoPixel library. I confirmed the versions of the library were the same between the Arduino sketch and the PlatformIO code. Arduino sketch works fine, the PlatformIO code doesn’t light up all the NeoPixels seems to only light up the first 10 or so. Then the remainder display as white. The code is identical between the two. I copied and pasted it from Arduino into PlatformIO then moved the loop() to the bottom. No other changes. This has me questioning PlatformIO which I really like from all other perspectives. But if I can’t trust the code copied in from Arduino IDE I’m not sure how to have confidence in PlatformIO.
#include <Adafruit_NeoPixel.h>
// Which pin on the Arduino is connected to the NeoPixels?
// On a Trinket or Gemma we suggest changing this to 1:
#define LED_PIN 6
// How many NeoPixels are attached to the Arduino?
#define LED_COUNT 21
// NeoPixel brightness, 0 (min) to 255 (max)
#define BRIGHTNESS 255 // Set BRIGHTNESS to about 1/5 (max = 255)
// Declare our NeoPixel strip object:
Adafruit_NeoPixel strip(LED_COUNT, LED_PIN, NEO_GRB);
// Argument 1 = Number of pixels in NeoPixel strip
// Argument 2 = Arduino pin number (most are valid)
// Argument 3 = Pixel type flags, add together as needed:
// NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
// NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
// NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
// NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
// NEO_RGBW Pixels are wired for RGBW bitstream (NeoPixel RGBW products)
// These lines are specifically to support the Adafruit Trinket 5V 16 MHz.
// Any other board, you can remove this part (but no harm leaving it):
#if defined(__AVR_ATtiny85__) && (F_CPU == 16000000)
clock_prescale_set(clock_div_1);
strip.begin(); // INITIALIZE NeoPixel strip object (REQUIRED)
strip.show(); // Turn OFF all pixels ASAP
strip.setBrightness(BRIGHTNESS);
strip.clear();
for (int i = 0; i < strip.numPixels(); i++) {
strip.setPixelColor(i, strip.Color(255, 255, 255));
delay(500);
strip.show();
twoColorWipe(strip.Color(255, 0, 0), strip.Color(0, 255, 0), 100);
whiteOverRainbow(50, 3);
rainbowFade2White(50, 3, 1);
colorWipe(strip.Color(255, 0, 0), 100);
colorWipe(strip.Color(0, 255, 0), 50);
colorWipe(strip.Color(0, 0, 255), 50);
colorWipe(strip.Color(255, 0, 0), 250);
// Fill strip pixels one after another with a color. Strip is NOT cleared
// first; anything there will be covered pixel by pixel. Pass in color
// (as a single 'packed' 32-bit value, which you can get by calling
// strip.Color(red, green, blue) as shown in the loop() function above),
// and a delay time (in milliseconds) between pixels.
void colorWipe(uint32_t color, int wait) {
for (int i = 0; i < strip.numPixels(); i++) { // For each pixel in strip...
strip.setPixelColor(i, color); // Set pixel's color (in RAM)
strip.show(); // Update strip to match
delay(wait); // Pause for a moment
void twoColorWipe(uint32_t color, uint32_t color2, int wait) {
if ((i % 2) == 0) {
strip.clear();
delay(wait);
} else {
strip.setPixelColor(i, color2); // Set pixel's color (in RAM)
strip.clear();
delay(wait);
for (int i = strip.numPixels(); i >= 0; i--) { // For each pixel in strip...
if ((i % 2) == 0) {
} else {
strip.clear();
if ((i % 2) == 0) {
} else {
delay(wait * 10);
void whiteOverRainbow(int whiteSpeed, int whiteLength) {
if (whiteLength >= strip.numPixels()) whiteLength = strip.numPixels() - 1;
int head = whiteLength - 1;
int tail = 0;
int loops = 3;
int loopNum = 0;
uint32_t lastTime = millis();
uint32_t firstPixelHue = 0;
for (;;) { // Repeat forever (or until a 'break' or 'return')
if (((i >= tail) && (i <= head)) || // If between head & tail...
((tail > head) && ((i >= tail) || (i <= head)))) {
strip.setPixelColor(i, strip.Color(0, 0, 0, 255)); // Set white
} else { // else set rainbow
int pixelHue = firstPixelHue + (i * 65536L / strip.numPixels());
strip.setPixelColor(i, strip.gamma32(strip.ColorHSV(pixelHue)));
strip.show(); // Update strip with new contents
// There's no delay here, it just runs full-tilt until the timer and
// counter combination below runs out.
firstPixelHue += 40; // Advance just a little along the color wheel
if ((millis() - lastTime) > whiteSpeed) { // Time to update head/tail?
if (++head >= strip.numPixels()) { // Advance head, wrap around
head = 0;
if (++loopNum >= loops) return;
if (++tail >= strip.numPixels()) { // Advance tail, wrap around
tail = 0;
lastTime = millis(); // Save time of last movement
void pulseWhite(uint8_t wait) {
for (int j = 0; j < 256; j++) { // Ramp up from 0 to 255
// Fill entire strip with white at gamma-corrected brightness level 'j':
strip.fill(strip.Color(0, 0, 0, strip.gamma8(j)));
strip.show();
delay(wait);
for (int j = 255; j >= 0; j--) { // Ramp down from 255 to 0
strip.show();
delay(wait);
void rainbowFade2White(int wait, int rainbowLoops, int whiteLoops) {
int fadeVal = 0, fadeMax = 100;
// Hue of first pixel runs 'rainbowLoops' complete loops through the color
// wheel. Color wheel has a range of 65536 but it's OK if we roll over, so
// just count from 0 to rainbowLoops*65536, using steps of 256 so we
// advance around the wheel at a decent clip.
for (uint32_t firstPixelHue = 0; firstPixelHue < rainbowLoops * 65536;
firstPixelHue += 256) {
// Offset pixel hue by an amount to make one full revolution of the
// color wheel (range of 65536) along the length of the strip
// (strip.numPixels() steps):
uint32_t pixelHue = firstPixelHue + (i * 65536L / strip.numPixels());
// strip.ColorHSV() can take 1 or 3 arguments: a hue (0 to 65535) or
// optionally add saturation and value (brightness) (each 0 to 255).
// Here we're using just the three-argument variant, though the
// second value (saturation) is a constant 255.
strip.setPixelColor(i, strip.gamma32(strip.ColorHSV(pixelHue, 255,
255 * fadeVal / fadeMax)));
strip.show();
delay(wait);
if (firstPixelHue < 65536) { // First loop,
if (fadeVal < fadeMax) fadeVal++; // fade in
} else if (firstPixelHue >= ((rainbowLoops - 1) * 65536)) { // Last loop,
if (fadeVal > 0) fadeVal--; // fade out
} else {
fadeVal = fadeMax; // Interim loop, make sure fade is at max
for (int k = 0; k < whiteLoops; k++) {
for (int j = 0; j < 256; j++) { // Ramp up 0 to 255
strip.show();
delay(1000); // Pause 1 second
for (int j = 255; j >= 0; j--) { // Ramp down 255 to 0
strip.show();
delay(500); // Pause 1/2 second
