So, recently i was using no problem an Leonardo pro micro in platformio, so i wanted to test some parts of the code in ESP32 or Arduino UNO, but when i build or upload i always get this error that i never had before:
The terminal process “C:\Users\Tuka.platformio\penv\Scripts\platformio.exe ‘run’, ‘–environment’, ‘esp32doit-devkit-v1’” terminated with exit code: 1.
> Executing task in folder ESP 32 test: C:\Users\Tuka\.platformio\penv\Scripts\platformio.exe run --environment esp32doit-devkit-v1 <
Processing esp32doit-devkit-v1 (platform: espressif32; board: esp32doit-devkit-v1; framework: arduino)
PLATFORM: Espressif 32 (3.2.0) > DOIT ESP32 DEVKIT V1
- framework-arduinoespressif32 3.10006.210326 (1.0.6)
- tool-esptoolpy 1.30000.201119 (3.0.0)
- toolchain-xtensa32 2.50200.97 (5.2.0)
Found 40 compatible libraries
|-- <Adafruit GFX Library> 1.10.7
JSONDecodeError: Expecting value: line 1 column 1 (char 0):
File "C:\Users\Tuka\.platformio\penv\lib\site-packages\platformio\builder\main.py", line 177:
File "C:\Users\Tuka\.platformio\packages\tool-scons\scons-local-4.1.0\SCons\Script\SConscript.py", line 591:
File "C:\Users\Tuka\.platformio\packages\tool-scons\scons-local-4.1.0\SCons\Script\SConscript.py", line 280:
File "C:\Users\Tuka\.platformio\platforms\espressif32\builder\main.py", line 225:
File "C:\Users\Tuka\.platformio\packages\tool-scons\scons-local-4.1.0\SCons\Util.py", line 658:
File "C:\Users\Tuka\.platformio\penv\lib\site-packages\platformio\builder\tools\platformio.py", line 62:
env.ProcessProjectDeps()
File "C:\Users\Tuka\.platformio\penv\lib\site-packages\platformio\builder\tools\platformio.py", line 140:
project_lib_builder = env.ConfigureProjectLibBuilder()
File "C:\Users\Tuka\.platformio\penv\lib\site-packages\platformio\builder\tools\piolib.py", line 1075:
_print_deps_tree(project)
File "C:\Users\Tuka\.platformio\penv\lib\site-packages\platformio\builder\tools\piolib.py", line 1051:
_print_deps_tree(lb, level + 1)
File "C:\Users\Tuka\.platformio\penv\lib\site-packages\platformio\builder\tools\piolib.py", line 1037:
pkg = PackageItem(lb.path)
File "c:\users\tuka\.platformio\penv\lib\site-packages\platformio\package\meta.py", line 405:
self.metadata = self.load_meta()
File "c:\users\tuka\.platformio\penv\lib\site-packages\platformio\package\meta.py", line 440:
return PackageMetaData.load(manifest_path)
File "c:\users\tuka\.platformio\penv\lib\site-packages\platformio\package\meta.py", line 391:
data = json.load(fp)
File "C:\Users\Tuka\.platformio\python3\lib\json\__init__.py", line 296:
parse_constant=parse_constant, object_pairs_hook=object_pairs_hook, **kw)
File "C:\Users\Tuka\.platformio\python3\lib\json\__init__.py", line 348:
return _default_decoder.decode(s)
File "C:\Users\Tuka\.platformio\python3\lib\json\decoder.py", line 337:
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "C:\Users\Tuka\.platformio\python3\lib\json\decoder.py", line 355:
raise JSONDecodeError("Expecting value", s, err.value) from None
