I’m trying to get VIM setup nicely with platformIO, and I’m having an issue with syntastic gcc/cpp linter not finding the header files. (everything else is working through the default Makefile as instructed)
I have to tell gcc where to find the header files, which of course differ per platform/board used. This neomake/neovim plugin gets the include paths from this command: pio -c vim run -t idedata -d $project_dir
, which I guess is a decent solution. But it seems like that command is unable to output ONLY the JSON data. It’s always wrapped in verbose stuff like:
========= [SUCCESS] Took 0.47 seconds ============
The neovim plugin I linked above seems to have the same issue, and works around it by looking for {
and }
to determine the beginning and end of the JSON output. I would like to not do that, and simply get the JSON data.
Is that possible? Can pio
or platformio
output only JSON? No other messages?
Or, any other way to get VIM/syntastic to cooperate?
Thanks.
