JLINK debugging first try error
Update:
I sent back my V8 probe to Amazon and received a V9 version (looks the same).
This works like a charm.
Now that I see how comfortable it is to debug in platformio, I am ordering an original JLINK EDU mini.
The only thing that did not work was the green restart button. It complained that a file is in use. Stopping and starting again worked.
Thank you for your help and assistance.
Csaba
Would you mind linking the amazon page what version worked nicely for you?
I’m also using the J-Link EDU Mini, which works like a charm compared to other stuff that I had rather a lot of problems with.
I got mine form AliExpress:
If you were to order these, there is no guarantee that you will get the same ones as I did. Most AliExpress stores are not manufactures but dealers. When they are short on stock, they will order from the supplier that can deliver a similar enough item at the lowest price.
This is the one that works here:
https://www.amazon.de/gp/product/B07SFWCLBT
I think the most important thing is to get a V9.
By the way, the plastic housing is identical, therefore the pictures don’t tell the difference.
I have a similar problem
I have created a new thread
