Hello all, I hope you are doing well as you receive this post.
I have been trying to learn how to use different debugging hardware and have been successful at using the ST-LINK/V2/some of its clones. I assumed the setup for both JLINK and STLINK would be very similar, but apparently they are a bit different. I followed the documentation as I thought it should be followed but I received this error message:
I am unsure what to do here considering I had to nothing with TCP/IP with a hardware debugger. And I also had this window pop up:
This is my current platformio.ini file config:
I just am confused about what to even do with IP, and since I do not know what to put in the box I have a feeling that this is the reason I am receiving errors. Any suggestions would be gratefully appreciated! Thank you!
Seems like a driver error to me. PlatformIO per the output above will try to use the native JLinkExe / JLinkGDBServerCLI to try to connect to the JLink. For that, the native JLink drivers (and not e.g. the WinUSB drivers) need to be installed.
This worked, I was thinking that maybe I needed driver but because the document did not show the link to that site, I assumed it was unnecessary. Just wondering, is the core_dir function I have in my platformio.ini file necessary then? I assumed that would be what fixes my driver issue at first.
