today, after generating new code from STMCubeMX with support for timers,
I encountered a strange problem when compiling this new code in PlatformIO:
It looks like files in STM32Cube/f4 package (after using “platformio update” comand) are missing some lines that are present in official STM32Cube GitHub repository (STMicroelectronics/STM32CubeF4, I can’t insert more than 2 links ) and that are being used in code generated by STMCubeMX.
Haa … interesting … to check the state of the used M4 ST lib is on my agenda in the context of my problem described here: Nucelo-F446RE optimization issue
Seems like the bintray packages there are created explicitly without them being in a github, or they’re in a private one. @valeros should now how it works internally.
Yes, that is probably the case. I created a repository for it anyway and updated the framework sources.
To use the new versions just add this to platformio.ini:
