I have a suspicion that this is related to the SoftDevice. I tried flashing example from the nrf52 SDK, and I got the same segfault address. Debugging a bit showed me that this occurs during BLE Stack (SoftDevice) initialization.
After I merged .hex file produced by ‘make’ command with SoftDevice .hex file from SDK, and flashed it, example started working. Maybe I need to write some kind of custom build command?
On the other hand, once I run load for merged .hex file, I could also load just make-produced .hex file (example code only) and it seems to work fine. Maybe I need to point platformIO to my softdevice hex, since it uses malformed or incompatible one?
I’m already using build_flags = -DNRF52_S132 in my platformio.ini - hackaBLE is based on nrf52832, which is s132 SoftDevice. SoftDevice that worked for me is from nRF52 SDK v15.3, s132_nrf52_6.1.1_softdevice.hex.
Does platformio produce code that isn’t yet merged with SoftDevice (or however it does that?), so I could try to merge it myself and upload it manually?
If it is a corrupted softdevice file, can you navigate to the path indicated by the code
So <home dir>/.platformio/packages/framework-arduinonrf52/cores/nRF5/SDK/components/softdevice/<softdevice>/hex/<hexfile> and then replace the hex file.
I tried putting in newer version of SoftDevice, but got the same issue as this guy:
It’s also seems like a relatively new issue? But also something is already in the package as a result of it. I tried changing URL to development version (platform = https://github.com/platformio/platform-nordicnrf52.git) in platformio.ini, but to no avail - I still get a segfault, although at a different address:
received signal SIGSEGV, Segmentation fault.
0x0001d27c in ?? ()
I also thought it may be a conflict between softdevices. So I went to gdb and ran
(gdb) target extended-remote /dev/ttyACM0
Remote debugging using /dev/ttyACM0
(gdb) monitor erase_mass
Target does not support this command.
(gdb) attach 1
Attaching to Remote target
warning: No executable has been specified and target does not support
determining executable automatically. Try using the "file" command.
0x0002b4a8 in ?? ()
erase..
(gdb) kill
Kill the program being debugged? (y or n) y
[Inferior 1 (Remote target) killed]
(gdb) run
Starting program:
Program received signal SIGSEGV, Segmentation fault.
0x00000000 in ?? ()
Which makes sense, I guess. But after I tried to upload code from platformio…
I still got a segfault at 0x00. So maybe issue is with flashing, somehow? What really bothered me is that gdb command for uploading is arm-none-eabi-gdb -nx --batch -ex "target extended-remote /dev/ttyACM0" -ex "monitor swdp_scan" -ex "attach 1" -ex load -ex compare-sections -ex kill /media/data/projects/BLE/BlinkyAdvert/.pio/build/hackaBLE/firmware.elf
I’m not sure how gdb processes this command line, but will this empy load command work? I’m not sure. At this point I’m honestly just saying ideas.
