Hi
I’m trying to start versioning my own project using platformio pre script
I’ve followed 2 methods, both ends with the same error. First one by adding !python:my_version_file.py into build_flags. (I’ll skip to the second method)
and the other method is by using extra_scripts.
I use git describe output to make version of my project.
I have 2 issues (3rd is less important now) :
When I hit pio run -v, It shows me less defines by 1 in verbose. For example it should define :
-DGIT_REVISION="%hash"
-DGIT_REVISION_NO=0x%hash
-DMEEZANI_VERSION=0.0.1
what I really see is only the first 2.
The second (more important issue, I get this error if appended CPP Defines (by this method or the first one) :
xtensa-esp32-elf-g++: fatal error: no input files
a full log with verbose :
PS C:\Users\Hamza\Documents\PlatformIO\Projects\piotest> pio run -v
Processing esp32doit-devkit-v1 (framework: arduino; platform: espressif32; board: esp32doit-devkit-v1; monitor_speed: 115200; upload_speed: 921600; build_flags: -w; extra_scripts: pre:git_rev_macro.py; lib_deps: https://github.com/meezani/FastLED.git)
<SCons.Script.SConscript.SConsEnvironment object at 0x00000148D01FFA90>
PLATFORM: Espressif 32 (2.0.0) > DOIT ESP32 DEVKIT V1
Found 27 compatible libraries
|-- <FastLED> 3.3.3+sha.1c3fbd0 [git+https://github.com/meezani/FastLED.git] (C:\Users\Hamza\Documents\PlatformIO\Projects\piotest\.pio\libdeps\esp32doit-devkit-v1\FastLED)
| |-- <SPI> 1.0 (C:\Users\Hamza\.platformio\packages\framework-arduinoespressif32\libraries\SPI)
xtensa-esp32-elf-g++ -o .pio\build\esp32doit-devkit-v1\lib237\FastLED\FastLED.cpp.o -c -fno-rtti -fno-exceptions -std=gnu++11 -w -Os -g3 -Wall -nostdlib -Wpointer-arith -Wno-error=unused-but-set-variable -Wno-error=unused-variable -mlongcalls -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -Wno-error=deprecated-declarations -Wno-error=unused-function -Wno-unused-parameter -Wno-sign-compare -fstack-protector -fexceptions -Werror=reorder -DGIT_REVISION="2dd02317cfad6998e11fe6563beee92190454f0b" -DGIT_REVISION_NO=0x2dd02317cfad6998e11fe6563beee92190454f0b
xtensa-esp32-elf-g++ -o .pio\build\esp32doit-devkit-v1\lib237\FastLED\bitswap.cpp.o -c -fno-rtti -fno-exceptions -std=gnu++11 -w -Os -g3 -Wall -nostdlib -Wpointer-arith -Wno-error=unused-but-set-variable -Wno-error=unused-variable -mlongcalls -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -Wno-error=deprecated-declarations -Wno-error=unused-function -Wno-unused-parameter -Wno-sign-compare -fstack-protector -fexceptions -Werror=reorder -DGIT_REVISION="2dd02317cfad6998e11fe6563beee92190454f0b" -DGIT_REVISION_NO=0x2dd02317cfad6998e11fe6563beee92190454f0b
compilation terminated.
xtensa-esp32-elf-g++ -o .pio\build\esp32doit-devkit-v1\lib237\FastLED\colorpalettes.cpp.o -c -fno-rtti -fno-exceptions -std=gnu++11 -w
xtensa-esp32-elf-g++ -o .pio\build\esp32doit-devkit-v1\lib237\FastLED\colorutils.cpp.o -c -fno-rtti -fno-exceptions -std=gnu++11 -w -Os -g3 -Wall -nostdlib -Wpointer-arith -Wno-error=unused-but-set-variable -Wno-error=unused-variable -mlongcalls -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -Wno-error=deprecated-declarations -Wno-error=unused-function -Wno-unused-parameter -Wno-sign-compare -fstack-protector -fexceptions -Werror=reorder -DGIT_REVISION="2dd02317cfad6998e11fe6563beee92190454f0b" -DGIT_REVISION_NO=0x2dd02317cfad6998e11fe6563beee92190454f0b
*** [.pio\build\esp32doit-devkit-v1\lib237\FastLED\FastLED.cpp.o] Error 1
*** [.pio\build\esp32doit-devkit-v1\lib237\FastLED\bitswap.cpp.o] Error 1
*** [.pio\build\esp32doit-devkit-v1\lib237\FastLED\colorpalettes.cpp.o] Error 1
*** [.pio\build\esp32doit-devkit-v1\lib237\FastLED\colorutils.cpp.o] Error 1
===================================================== [FAILED] Took 4.37 seconds =====================================================
However I’ve created a sample project to reproduce the issue, It’s uploaded here.
For a quick eye :
git_rev_macro.py :
import subprocess
projectTag = (
subprocess.run(['git', 'describe','--tags','--abbrev=0'], capture_output=True, text=True).stdout
revision = (
subprocess.run(['git', 'rev-parse','HEAD','--short=10'], capture_output=True, text=True).stdout
gitDescribeOutput = (
subprocess.run(['git', 'describe','--tags'], capture_output=True, text=True).stdout
info = gitDescribeOutput.split('-')
Import("env")
print(env)
env.Append(CPPDEFINES=[
("GIT_REV", "\"%s\""%revision.strip()),
("GIT_REV_NO", "0x%s"%revision),
("MEEZANI_VERSION", projectTag),
# ("AHEAD_COMMITS", info[1]),
platformio.ini:
[platformio]
default_envs = esp32doit-devkit-v1
[common]
upload_speed = 921600
[env:esp32doit-devkit-v1]
framework = ${common.framework}
board = esp32doit-devkit-v1
monitor_speed = ${common.monitor_speed}
upload_speed = ${common.upload_speed}
build_flags = -w
extra_scripts = pre:git_rev_macro.py
lib_deps = ${common.lib_deps}
The project is empty. (except for #include <FastLED.h> after <Arduino.h>)
