Trying to compile firmware for my Ender 3 v2 with Creality 4.2.2 board, however I keep running into STM32F103RET6_creality_maple error. Any help would be appreciated!
================================================= [FAILED] Took 7.17 seconds =================================================
Environment Status Duration
STM32F103RET6_creality_maple FAILED 00:00:07.166
=========================================== 1 failed, 0 succeeded in 00:00:07.166 ===========================================
The terminal process “C:\Users\allen.platformio\penv\Scripts\platformio.exe ‘run’” terminated with exit code: 1.
Any other error messages in the lines previous to that one you posted?
Cheers,
Norm.
Yes, I had the v4 error which I fixed to v4.2.2. Wouldnt even start trying to compile until I did.
Sorry. I meant, did you see any errors during the compilation which has failed?
Also, is this post of any use? Issue building STM32F103RET6_creality.
Cheers,
Norm.
- I downloaded the latest nightly Marlin v2.0.x bugfix zip archive.
- I downloaded the nightly bugfix config zip archive for v2.0.x
- I uncompressed both.
- I copied the bugfix config from
examples/creality/Ender3 V2/CrealityV422/CrealityUI/*
to Marlin/*
overwriting the two config files already there.
- I edited
platformio.ini
and changed:
default_envs
board
- Saved the ini file.
pio run -t clean
pio run
The result was a clean compilation:
Building .pio/build/STM32F103RE_creality_maple/firmware-20220220-135443.bin
======================================= [SUCCESS] Took 89.78 seconds =======================================
STM32F103RE_creality_maple SUCCESS 00:01:29.781
My environment is Linux Mint 20.3 64 bit on a dual core, 16 year old laptop. Python version is 3.8.10.
I do not own a 3D printer, yet.
Edited because my spelling is atrocious.
Cheers,
Norm.
Ill check that when I get home. I didn’t notice any other errors, but I’m using jyers marlin.
I used the official version from Download | Marlin Firmware.
Cheers,
Norm.
