So the other day I got a notice to start using VSCode so I installed it and tried to use it for a few hours but quickly came to the conclusion that it was not for me. I switched back to ATOM with PlatformIO and went back to work. I have been working on development in ESP32 and commonly upload firmware and spiffs with the terminal command:
pio run --target upload && pio run --target uploadfs
However I get all sorts of errors now. If I click the Platformio flash button in ATOM that seems to work fine, but if I try to upload firmware using the command pio run --target upload I get the following:
Assembler messages:
Fatal error: can't create .pio/build/development/libb03/ESP Async WebServer_ID306/WebAuthentication.cpp.o: No such file or directory
scons: *** [.pio/build/development/libb03/ESP Async WebServer_ID306/WebAuthentication.cpp.o] Error 1
Assembler messages:
Fatal error: can't create .pio/build/development/libb03/ESP Async WebServer_ID306/WebHandlers.cpp.o: No such file or directory
scons: *** [.pio/build/development/libb03/ESP Async WebServer_ID306/WebHandlers.cpp.o] Error 1
Assembler messages:
Fatal error: can't create .pio/build/development/libb03/ESP Async WebServer_ID306/SPIFFSEditor.cpp.o: No such file or directory
scons: *** [.pio/build/development/libb03/ESP Async WebServer_ID306/SPIFFSEditor.cpp.o] Error 1
Assembler messages:
Fatal error: can't create .pio/build/development/libb03/ESP Async WebServer_ID306/AsyncEventSource.cpp.o: No such file or directory
scons: *** [.pio/build/development/libb03/ESP Async WebServer_ID306/AsyncEventSource.cpp.o] Error 1
Assembler messages:
Fatal error: can't create .pio/build/development/libb03/ESP Async WebServer_ID306/WebServer.cpp.o: No such file or directory
scons: *** [.pio/build/development/libb03/ESP Async WebServer_ID306/WebServer.cpp.o] Error 1
Assembler messages:
Fatal error: can't create .pio/build/development/libb03/ESP Async WebServer_ID306/AsyncWebSocket.cpp.o: No such file or directory
scons: *** [.pio/build/development/libb03/ESP Async WebServer_ID306/AsyncWebSocket.cpp.o] Error 1
Assembler messages:
Fatal error: can't create .pio/build/development/libb03/ESP Async WebServer_ID306/WebResponses.cpp.o: No such file or directory
scons: *** [.pio/build/development/libb03/ESP Async WebServer_ID306/WebResponses.cpp.o] Error 1
Assembler messages:
Fatal error: can't create .pio/build/development/libb03/ESP Async WebServer_ID306/WebRequest.cpp.o: No such file or directory
scons: *** [.pio/build/development/libb03/ESP Async WebServer_ID306/WebRequest.cpp.o] Error 1
OSError: [Errno 2] No such file or directory: '/Users/traviselliott/Documents/PlatformIO/Projects/ESP32_MQTT_Gateway/.pio/build/.sconsign.dblite':
File "/Users/traviselliott/.platformio/packages/tool-scons/script/../engine/SCons/Script/Main.py", line 1346:
_exec_main(parser, values)
File "/Users/traviselliott/.platformio/packages/tool-scons/script/../engine/SCons/Script/Main.py", line 1309:
_main(parser)
File "/Users/traviselliott/.platformio/packages/tool-scons/script/../engine/SCons/Script/Main.py", line 1091:
nodes = _build_targets(fs, options, targets, target_top)
File "/Users/traviselliott/.platformio/packages/tool-scons/script/../engine/SCons/Script/Main.py", line 1283:
jobs.run(postfunc = jobs_postfunc)
File "/Users/traviselliott/.platformio/packages/tool-scons/script/../engine/SCons/Job.py", line 113:
postfunc()
File "/Users/traviselliott/.platformio/packages/tool-scons/script/../engine/SCons/Script/Main.py", line 1280:
SCons.SConsign.write()
File "/Users/traviselliott/.platformio/packages/tool-scons/script/../engine/SCons/SConsign.py", line 109:
syncmethod()
File "/Users/traviselliott/.platformio/packages/tool-scons/script/../engine/SCons/dblite.py", line 129:
self._os_unlink(self._file_name)
Exception OSError: (2, 'No such file or directory', '/Users/traviselliott/Documents/PlatformIO/Projects/ESP32_MQTT_Gateway/.pio/build/.sconsign.dblite') in <bound method dblite.__del__ of <SCons.dblite.dblite object at 0x10bfe5610>> ign
ored
Any ideas what in the world is going on here? I’m lost and I can’t find anything on this other than to remove .pioenvs directory from the project but that directory does not exist in the project folder.
