Hi there!
I’m having trouble linking a local library that I wrote:
C:/Users/<user>/.platformio/packages/toolchain-rp2040-earlephilhower/bin/../lib/gcc/arm-none-eabi/14.3.0/../../../../arm-none-eabi/bin/ld.exe: .pio\build\default\src\main.cpp.o: in function `setup':
main.cpp:(.text.setup+0x6): undefined reference to `_ZN6Bme280C1Eh'
My project structure looks like this:
|- platformio.ini
|-- src
| |-- main.cpp
|-- lib
| |-- i2c
| | |-- src
| | | |-- bme280.cpp
| | | |-- bme280.h
| | | |-- i2c.cpp
| | | |-- i2c.h
| | |-- library.json
platformio.ini:
[env]
platform = https://github.com/maxgerhardt/platform-raspberrypi.git
board = adafruit_feather_thinkink
[env:default]
adafruit/Adafruit NeoPixel@^1.15.2
symlink://lib/i2c
main.cpp:
#include <bme280.h>
Bme280 bme;
bme.reset();
byte* chipId = bme.readBytes(0xD0, 1);
Serial.printf("chip id: %d\n", chipId);
delete chipId;
bme280.h:
// bme280.h contains header code for the BME280 sensor from bosch
#ifndef BME280_H
#define BME280_H
#include "i2c.h"
#define BME280_ADDR 0x76
#define BME280_ADDR_ALT 0x77
class Bme280 : public I2C {
public:
Bme280(byte addr = BME280_ADDR);
void reset() override;
bme280.cpp:
// bme280.cpp contains implementation code for the BME280 sensor from bosch
#include "bme280.h"
// Performs a soft reset
void Bme280::reset() {
Wire.beginTransmission(this->addr);
// Register is 0xE0
Wire.write(0xE0);
// Command to reset is 0xB6
Wire.write(0xB6);
byte out = Wire.endTransmission();
if (out) {
Serial.printf("Reset returned code: %d\n", out);
i2c.h:
// i2c.h contains header code for interfacing with i2c devices
#ifndef I2C_H
#define I2C_H
#include <Wire.h>
#define WRITE_MODE 0x00
#define READ_MODE 0x80
class I2C {
public:
I2C(byte addr);
virtual void reset() = 0;
virtual byte* readBytes(uint registerAddr, uint numBytes);
protected:
byte addr;
i2c.cpp:
// i2c.cpp contains implementation code for interfacing with i2c devices
#include "i2c.h"
I2C::I2C(byte addr) {
this->addr = addr;
Wire.begin();
Serial.begin();
while(!Serial);
// Read bytes from a register
byte* I2C::readBytes(uint registerAddr, uint numBytes) {
// Read chip id
// Which register to read
Wire.write(registerAddr);
if (out) {
Serial.printf("Failed to write with error code %d\n", out);
return NULL;
Wire.beginTransmission(this->addr | READ_MODE);
if (out) {
Serial.printf("Failed to read with error code %d\n", out);
return NULL;
Wire.requestFrom(this->addr, numBytes);
byte* returnArray = new byte[numBytes];
for (int i = 0; i < numBytes && Wire.available(); i++) {
byte b = Wire.read();
return returnArray;
It does seem to be seeing all my files:
Compiling .pio\build\default\lib5c9\i2c\bme280.cpp.o
Compiling .pio\build\default\lib5c9\i2c\i2c.cpp.o
Archiving .pio\build\default\lib5c9\libi2c.a
I’m sure I’m missing something simple as it’s also been years since I’ve written c++, but I set up my project folder as best I could, following the docs. Does anyone have any ideas?
