My platformio.ini looks like
[env]
lib_ldf_mode = deep
test_build_src = yes
test_framework = googletest
extra_scripts = pre:tools/extra/add_includes.py
vovagorodok/ArduinoBleChess@^0.7.2
vovagorodok/ArduinoBleOTA@^2.0.6
vovagorodok/ArduinoBleBattery@^1.0.1
vovagorodok/ArduinoStreamLogger@^1.1.10
vovagorodok/ArduinoBuzzer@^1.0.1
vovagorodok/ArduinoPin@^1.2.2
vovagorodok/ArrayUtils@^1.3.7
vovagorodok/Servo@^1.0.0
vovagorodok/PicChess@^0.9.1
h2zero/NimBLE-Arduino@^1.4.3
laurb9/StepperDriver@^1.4.1
fastled/FastLED@^3.10.3
-std=c++2a
-std=gnu++2a
-D LOG_LEVEL_TRACE
build_unflags =
-std=gnu++11
[env:smart_leds_hardware]
${env.build_flags}
-D SMART_LEDS_BOARD
[env:leds_hardware]
${env.build_flags}
-D LEDS_BOARD
[env:motors_hardware]
${env.build_flags}
-D MOTORS_BOARD
[env:test]
platform = native
board =
framework =
fabiobatsilva/ArduinoFake@^0.4.0
For env:test I have an issue
Updating metadata for the vscode IDE...
UserSideException: Processing test (platform: native; board: ; framework: )
Error: BoardConfig: Board is not defined
========================== [FAILED] Took 0.21 seconds ==========================
Line framework = successfully override framework = arduino of [env]. But board = doesn’t override
Don’t want to copy
for each hardware, because all use same esp32dev
For native platform you don’t specify a board or a framework. See Native — PlatformIO latest documentation
But board = and framework = inherit from [env]. Will be nice to have possibility do disable board define like for framework in order to prepare environment for unit/module testing
Don’t understand how it solve this case. Can You show example of solution?
To avoid the inheritence from [env] use interpolation of values and extends
Examples are included in the links I have posted above.
Changed structure to something like
[env]
lib_ldf_mode = deep
[hardware]
test_filter = test_hardware/*
extends = hardware
${env.build_flags}
-D SMART_LEDS_BOARD
[env:leds_hardware]
extends = hardware
${env.build_flags}
-D LEDS_BOARD
extends = hardware
${env.build_flags}
-D MOTORS_BOARD
[env:test]
platform = native
test_filter = test_module/*
Added two filters for hardware tests test_filter = test_hardware/* and for module/unit tests test_filter = test_module/*.
But after adding test_filter line, test don’t want to run
Executing task: platformio test --environment smart_leds_hardware
Verbosity level can be increased via `-v, -vv, or -vvv` option
Collected 1 tests
================================ 0 test cases: 0 succeeded in 00:00:00.000 ================================
After removing line with test_filter all works correctly. Folders structure
test
|_ test_hardware
|_ main.cpp
|_ test_module // planed to add
|_ main.cpp
Looking to test_filter — PlatformIO latest documentation it should work. Same issue with test_ignore
@sivar2311 have You idea why test_filter doesn’t work, maybe here is an PlatformIO issue with that?
Does your test_filter expression and folder structure match the one found in official examples? https://github.com/platformio/platformio-examples/tree/develop/unit-testing/calculator
Looks that rename main.cpp as
test
|_ test_hardware
|_ test_hardware.cpp
|_ test_module
|_ test_module.cpp
resolve the issue.
How to filter more than one like this
test_filter =
test_module
test_module2
EDIT: Checked. Yes like this.
Final solution is using Interpolation of Values — PlatformIO latest documentation and extends — PlatformIO latest documentation
[env]
lib_ldf_mode = deep
[hardware]
extends = hardware
${env.build_flags}
-D SMART_LEDS_BOARD
[env:leds_hardware]
extends = hardware
${env.build_flags}
-D LEDS_BOARD
extends = hardware
${env.build_flags}
-D MOTORS_BOARD
[env:test]
platform = native
test_filter =
test_module
test_module2
With folders structure as in https://github.com/platformio/platformio-examples/tree/develop/unit-testing/calculator
test
|_ test_hardware
|_ test_hardware.cpp
|_ test_module
|_ test_module.cpp
|_ test_module2
|_ test_module2.cpp
Thanks @sivar2311 @maxgerhardt
