This stupid script worked days ago.
This is a solar tracker script from the Arduino site with dozens of users. I’m sure it works. I removed all references to motors, s it’s only using LDR to detect light and report it in serial monitor. That part of the program was working.
I need to understand why I get this error:
Compiling .pio\build\esp32dev\FrameworkArduino\MD5Builder.cpp.o
src\main.cpp:32:2:
error: ‘Serial’ does not name a type
Serial.print(eastLDR);
//Sun Tracker Sketch
//This sketch is designed for use with a 9gram servo, able
//to be powered directly from the Arduinio without an external
//power source. For fritzing diagram, see Github repository
//https://github.com/nickalanf/Arduino–Projects
//The Serial monitor section is for debugging purposes, or for general interest
//one once the device is functioning correctly, can be diasabled
//Sketch by FIELDING - 8/2/18
int eLDRPin = 2; // Assign pins to the LDR’s
int wLDRPin = 4;
int eastLDR = 0; //Create variables to store to LDR readings
int westLDR = 0;
int difference = 0; //Create a variable to compare the two LDR’s
int error = 10; // Variable for is there is a noticable difference between the two LDR’s
Serial.begin(9600);
eastLDR = analogRead(eLDRPin); //Read the LDR values
westLDR = analogRead(wLDRPin);
difference = eastLDR - westLDR ; //Check the difference
Serial.print(eastLDR); //Serial monitor can be useful for debugging/setting up
Serial.print(" - “); //Use it to see if your LDR’s are noticeably different when
Serial.print(westLDR); //They have equal light shining on them, if so, correct with the error value
Serial.print(” - “);
Serial.print(difference);
Serial.println(”.");
delay(1000);
CONFIGURATION: Redirecting...
PLATFORM: Espressif 32 1.12.4 > Espressif ESP32 Dev Module
Found 34 compatible libraries
Scanning dependencies…
Compiling .pio\build\esp32dev\src\main.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\Print.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\Stream.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\StreamString.cpp.o
src\main.cpp:32:2: error: ‘Serial’ does not name a type
src\main.cpp:33:2: error: ‘Serial’ does not name a type
src\main.cpp:34:2: error: ‘Serial’ does not name a type
src\main.cpp:35:2: error: ‘Serial’ does not name a type
src\main.cpp:36:2: error: ‘Serial’ does not name a type
src\main.cpp:37:2: error: ‘Serial’ does not name a type
src\main.cpp:38:2: error: ‘Serial’ does not name a type
src\main.cpp:39:2: error: ‘Serial’ does not name a type
src\main.cpp:40:7: error: expected constructor, destructor, or type conversion before ‘(’ token
delay(1000);
src\main.cpp:41:2: error: expected declaration before ‘}’ token
*** [.pio\build\esp32dev\src\main.cpp.o] Error 1
================================================= [FAILED]
I think your code is “broken”
This, from your first post with code:
Serial.begin(9600);
delay(1000);
Should be, I think, this:
// Add this...
Serial.begin(9600);
// Remove this line...
//Serial.begin(9600);
// Remove this brace..
// Now the remainder is once more part of loop().
delay(1000);
HTH
Cheers,
Norm.
