I am trying to define a generic STM32H750VBTX board, based on the datasheet and examples of other generic STM32 boards.
Does this seem correct? Especially the RAM/ROM sizes, can I just take the numbers from the datasheet or are there other considerations such as memory type and segmentation (see linker file below)?
My proposed genericSTM32H750VBTX.json board definition:
"build": {
"core": "stm32",
"cpu": "cortex-m7",
"extra_flags": "-DSTM32H7xx -DSTM32H750xx",
"f_cpu": "480000000L",
"mcu": "stm32h750vbt6",
"product_line": "STM32H750xx",
"variant": "STM32H7xx/H742V(G-I)(H-T)_H743V(G-I)(H-T)_H750VBT_H753VI(H-T)"
"debug": {
"jlink_device": "STM32H750VB",
"openocd_target": "stm32h7x",
"svd_path": "STM32H750.svd"
"frameworks": [
"arduino",
"cmsis",
"stm32cube",
"libopencm3"
"name": "STM32H750VBTX (1024k RAM. 128k Flash)",
"upload": {
"maximum_ram_size": 1048576,
"maximum_size": 131072,
"protocol": "serial",
"protocols": [
"blackmagic",
"dfu",
"jlink",
"serial",
"stlink"
"url": "https://www.st.com/en/microcontrollers-microprocessors/stm32h750vb.html",
"vendor": "Generic"
BTW, I am using it with Cube IDE generated files, no framework, and this linker file from Cube IDE:
** File : LinkerScript.ld
** Author : STM32CubeIDE
** Abstract : Linker script for STM32H7 series
** 128Kbytes FLASH and 1056Kbytes RAM
** Set heap size, stack size and stack location according
** to application requirements.
** Set memory bank area and size if external memory is used.
** Target : STMicroelectronics STM32
** Distribution: The file is distributed as is, without any warranty
** of any kind.
** @attention
** Copyright (c) 2023 STMicroelectronics.
** All rights reserved.
** This software is licensed under terms that can be found in the LICENSE file
** in the root directory of this software component.
** If no LICENSE file comes with this software, it is provided AS-IS.
/* Entry Point */
ENTRY(Reset_Handler)
/* Highest address of the user mode stack */
_estack = ORIGIN(RAM_D1) + LENGTH(RAM_D1); /* end of RAM */
/* Generate a link error if heap and stack don't fit into RAM */
_Min_Heap_Size = 0x1000; /* required amount of heap */
_Min_Stack_Size = 0x400; /* required amount of stack */
/* Specify the memory areas */
MEMORY
FLASH (rx) : ORIGIN = 0x08000000, LENGTH = 128K
DTCMRAM (xrw) : ORIGIN = 0x20000000, LENGTH = 128K
RAM_D1 (xrw) : ORIGIN = 0x24000000, LENGTH = 512K
RAM_D2 (xrw) : ORIGIN = 0x30000000, LENGTH = 288K
RAM_D3 (xrw) : ORIGIN = 0x38000000, LENGTH = 64K
ITCMRAM (xrw) : ORIGIN = 0x00000000, LENGTH = 64K
/* Define output sections */
SECTIONS
/* The startup code goes first into FLASH */
.isr_vector :
. = ALIGN(4);
KEEP(*(.isr_vector)) /* Startup code */
. = ALIGN(4);
} >FLASH
/* The program code and other data goes into FLASH */
.text :
. = ALIGN(4);
*(.text) /* .text sections (code) */
*(.text*) /* .text* sections (code) */
*(.glue_7) /* glue arm to thumb code */
*(.glue_7t) /* glue thumb to arm code */
*(.eh_frame)
KEEP (*(.init))
KEEP (*(.fini))
. = ALIGN(4);
_etext = .; /* define a global symbols at end of code */
} >FLASH
/* Constant data goes into FLASH */
.rodata :
. = ALIGN(4);
*(.rodata) /* .rodata sections (constants, strings, etc.) */
*(.rodata*) /* .rodata* sections (constants, strings, etc.) */
. = ALIGN(4);
} >FLASH
.ARM.extab : { *(.ARM.extab* .gnu.linkonce.armextab.*) } >FLASH
.ARM : {
__exidx_start = .;
*(.ARM.exidx*)
__exidx_end = .;
} >FLASH
.preinit_array :
PROVIDE_HIDDEN (__preinit_array_start = .);
KEEP (*(.preinit_array*))
PROVIDE_HIDDEN (__preinit_array_end = .);
} >FLASH
.init_array :
PROVIDE_HIDDEN (__init_array_start = .);
KEEP (*(SORT(.init_array.*)))
KEEP (*(.init_array*))
PROVIDE_HIDDEN (__init_array_end = .);
} >FLASH
.fini_array :
PROVIDE_HIDDEN (__fini_array_start = .);
KEEP (*(SORT(.fini_array.*)))
KEEP (*(.fini_array*))
PROVIDE_HIDDEN (__fini_array_end = .);
} >FLASH
/* used by the startup to initialize data */
_sidata = LOADADDR(.data);
/* Initialized data sections goes into RAM, load LMA copy after code */
.data :
. = ALIGN(4);
_sdata = .; /* create a global symbol at data start */
*(.data) /* .data sections */
*(.data*) /* .data* sections */
*(.RamFunc) /* .RamFunc sections */
*(.RamFunc*) /* .RamFunc* sections */
. = ALIGN(4);
_edata = .; /* define a global symbol at data end */
} >RAM_D1 AT> FLASH
/* Uninitialized data section */
. = ALIGN(4);
.bss :
/* This is used by the startup in order to initialize the .bss section */
_sbss = .; /* define a global symbol at bss start */
__bss_start__ = _sbss;
*(.bss)
*(.bss*)
*(COMMON)
. = ALIGN(4);
_ebss = .; /* define a global symbol at bss end */
__bss_end__ = _ebss;
} >RAM_D1
/* User_heap_stack section, used to check that there is enough RAM left */
._user_heap_stack :
. = ALIGN(8);
PROVIDE ( end = . );
PROVIDE ( _end = . );
. = . + _Min_Heap_Size;
. = . + _Min_Stack_Size;
. = ALIGN(8);
} >RAM_D1
/* Remove information from the standard libraries */
/DISCARD/ :
libc.a ( * )
libm.a ( * )
libgcc.a ( * )
.ARM.attributes 0 : { *(.ARM.attributes) }
