Thanks!
That’s the whole error. I copied it from the middle window, not the terminal.
And it is in 1306.h.
That’s why I think it must be fixable, it’s an Adafruit product.
It’s creating on/off for pixels, not making an int.
Thanks!
Morning Joe.
What are the next couple of lines after the error please? Is one of then suspiciously similar to:
note: in expansion of macro ‘xxxxxx’
If so, you are probably defining a macro with the same name as another variable/function somewhere else in the code.
Search the code for SSD1306_BLACK.
Cheers,
Norm.
Another ‘wild guess’ (without seeing the context where the error occurs - i.e. where the macro is expanded) is that the comment might be causing the compiler issues.
Some compilers will nicely remove comments from the #define line but others do a simple text substitution that includes the comment and so generates all sorts of errors later on.
Susan
Ok, I’ve done a Google search for SSD1306_BLACK and this is one page that came up in the results:
https://adafruit.github.io/Adafruit_SSD1306/html/_adafruit___s_s_d1306_8h.html
It seems that the macro is defined in the Adafruit SSD1306 library, more specifically in the file Adafruit_SSD1306.h
– are you using this file in your code? If so, you don’t need to #define SSD1306_BLACK 0
yourself.
Or, is the error occurring in this actual file?
Cheers,
Norm.
