Is there a way to have multiple main files for different builds?
I’m writing 2 programs that will run on two separate Arduino’s, but they share a lot of common code. Is there a way to have different main files within one project?
The src files would look like:
  • main1.cpp
  • main2.cpp
  • common.cpp
Just doing it like that of course results in multiple definition errors for init and loop.
Check the src_filter option, different sections can have different filters:
http://docs.platformio.org/en/latest/projectconf/section_env_build.html
Or use -Dname in build_flags to define two names and then #ifdef in your code.
I tried to do something like this in platformio.ini:
[env:master]
board = uno
src_filter =
    ${common_env_data.build_flags}
    -<src/slave.cpp>
[env:slave]
board = uno
src_filter =
    -<src/slave.cpp>
But that does’t work as common_env_data isn’t defined, how should I get the default build_flags? And am I going in the right direction?
if you use ${common_env_data.build_flags}, then you have to have a section like this:
[common_env_data]
build_flags = ...
But this might be a simpler way:
[env:master]
build_flags = -DMASTER
[env:slave]
build_flags = -DSLAVE
Then use #ifdef MASTER and #ifdef SLAVE around your code.
