As reported on the two releases pages with no explanation as to the downgrade from 5.2.1 to 5.1.2
Hi @parmstrong
Have you checked that it really is a downgrade?
When I compile an ESP-IDF project I see the following output:
Processing esp32-s3-devkitc-1 (platform: espressif32 @ 6.7.0; board: esp32-s3-devkitc-1; framework: espidf)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/esp32-s3-devkitc-1.html
PLATFORM: Espressif 32 (6.7.0) > Espressif ESP32-S3-DevKitC-1-N8 (8 MB QD, No PSRAM)
HARDWARE: ESP32S3 240MHz, 320KB RAM, 8MB Flash
DEBUG: Current (esp-builtin) On-board (esp-builtin) External (cmsis-dap, esp-bridge, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
- framework-espidf @ 3.50201.0 (5.2.1)
- tool-cmake @ 3.16.4
- tool-idf @ 1.0.1
- tool-mconf @ 1.4060000.20190628 (406.0.0)
- tool-ninja @ 1.9.0
- tool-riscv32-esp-elf-gdb @ 11.2.0+20220823
- tool-xtensa-esp-elf-gdb @ 11.2.0+20230208
- toolchain-esp32ulp @ 1.23500.220830 (2.35.0)
- toolchain-riscv32-esp @ 13.2.0+20230928
- toolchain-xtensa-esp-elf @ 13.2.0+20230928
Note the versions used:
Therefore, I rather suspect a typo in the release note
