I’m trying to compile a project for ESP32 on arm64 windows 11. First the platformio couldn’t find python (even though it was in the path and even when I was pointing it to the exact location of python), then it went into an endless loop of “platformio installed - restart vscode - installing platformio” and then finally it was installed, but the build fails with:
Resolving iec-nugget dependencies...
Already up-to-date.
Updating metadata for the vscode IDE...
UserSideException: Processing iec-nugget (board: esp32-16mb; platform: espressif32 @ 6.3.2; framework: espidf)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/esp32-16mb.html
PLATFORM: Espressif 32 (6.3.2) > Meatloaf v1 16MB
HARDWARE: ESP32 240MHz, 320KB RAM, 16MB Flash
DEBUG: Current (cmsis-dap) External (cmsis-dap, esp-bridge, esp-prog, ftdi, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
- framework-espidf @ 3.50002.230601 (5.0.2)
- tool-cmake @ 3.16.4
- tool-idf @ 1.0.1
- tool-mconf @ 1.4060000.20190628 (406.0.0)
- tool-ninja @ 1.9.0
- toolchain-esp32ulp @ 1.23500.220830 (2.35.0)
- toolchain-xtensa-esp32 @ 11.2.0+2022r1
Installing ESP-IDF's Python dependencies
Collecting urllib3<2
Using cached urllib3-1.26.20-py2.py3-none-any.whl.metadata (50 kB)
Collecting cryptography~=41.0.1
Using cached cryptography-41.0.7.tar.gz (630 kB)
Installing build dependencies: started
Installing build dependencies: finished with status 'error'
error: subprocess-exited-with-error
pip subprocess to install build dependencies did not run successfully.
\u2502 exit code: 1
\u2570\u2500> [61 lines of output]
Collecting setuptools>=61.0.0
Using cached setuptools-77.0.1-py3-none-any.whl.metadata (6.7 kB)
Collecting wheel
Using cached wheel-0.45.1-py3-none-any.whl.metadata (2.3 kB)
Collecting cffi>=1.12
Using cached cffi-1.17.1.tar.gz (516 kB)
Installing build dependencies: finished with status 'done'
Getting requirements to build wheel: started
Getting requirements to build wheel: finished with status 'error'
× Getting requirements to build wheel did not run successfully.
│ exit code: 1
╰─> [36 lines of output]
File "C:\Users\qus\.platformio\penv\.espidf-5.0.2\Lib\site-packages\pip\_vendor\pyproject_hooks\_in_process\_in_process.py", line 389, in <module>
main()
File "C:\Users\qus\.platformio\penv\.espidf-5.0.2\Lib\site-packages\pip\_vendor\pyproject_hooks\_in_process\_in_process.py", line 373, in main
json_out["return_val"] = hook(**hook_input["kwargs"])
File "C:\Users\qus\.platformio\penv\.espidf-5.0.2\Lib\site-packages\pip\_vendor\pyproject_hooks\_in_process\_in_process.py", line 143, in get_requires_for_build_wheel
return hook(config_settings)
File "C:\Users\qus\AppData\Local\Temp\pip-build-env-4aqfl66c\overlay\Lib\site-packages\setuptools\build_meta.py", line 334, in get_requires_for_build_wheel
return self._get_build_requires(config_settings, requirements=[])
File "C:\Users\qus\AppData\Local\Temp\pip-build-env-4aqfl66c\overlay\Lib\site-packages\setuptools\build_meta.py", line 304, in _get_build_requires
self.run_setup()
File "C:\Users\qus\AppData\Local\Temp\pip-build-env-4aqfl66c\overlay\Lib\site-packages\setuptools\build_meta.py", line 320, in run_setup
exec(code, locals())
File "<string>", line 126, in <module>
File "<string>", line 105, in uses_msvc
File "C:\Users\qus\AppData\Local\Temp\pip-build-env-4aqfl66c\overlay\Lib\site-packages\setuptools\_distutils\command\config.py", line 215, in try_compile
self._compile(body, headers, include_dirs, lang)
File "C:\Users\qus\AppData\Local\Temp\pip-build-env-4aqfl66c\overlay\Lib\site-packages\setuptools\_distutils\command\config.py", line 131, in _compile
self.compiler.compile([src], include_dirs=include_dirs)
File "C:\Users\qus\AppData\Local\Temp\pip-build-env-4aqfl66c\overlay\Lib\site-packages\setuptools\_distutils\compilers\C\msvc.py", line 384, in compile
self.initialize()
File "C:\Users\qus\AppData\Local\Temp\pip-build-env-4aqfl66c\overlay\Lib\site-packages\setuptools\_distutils\compilers\C\msvc.py", line 294, in initialize
vc_env = _get_vc_env(plat_spec)
File "C:\Users\qus\AppData\Local\Temp\pip-build-env-4aqfl66c\overlay\Lib\site-packages\setuptools\_distutils\compilers\C\msvc.py", line 155, in _get_vc_env
raise DistutilsPlatformError(
...<3 lines>...
distutils.errors.DistutilsPlatformError: Microsoft Visual C++ 14.0 or greater is required. Get it with "Microsoft C++ Build Tools": https://visualstudio.microsoft.com/visual-cpp-build-tools/
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
│ exit code: 1
╰─> See above for output.
[end of output]
\u2502 exit code: 1
\u2570\u2500> See above for output.
*** Error 1
Installing windows-curses package
ERROR: Could not find a version that satisfies the requirement windows-curses (from versions: none)
ERROR: No matching distribution found for windows-curses
*** Error 1
-- Building ESP-IDF components for target esp32
-- Configuring incomplete, errors occurred!
See also "C:/Users/qus/Develop/meatloaf-specialty/.pio/build/iec-nugget/CMakeFiles/CMakeOutput.log".
fatal: not a git repository (or any of the parent directories): .git
CMake Error at C:/Users/qus/.platformio/packages/framework-espidf/tools/cmake/build.cmake:519 (message):
C:\Users\qus\.platformio\penv\.espidf-5.0.2\Scripts\python.exe: Error while
finding module specification for 'idf_component_manager.prepare_components'
(ModuleNotFoundError: No module named 'idf_component_manager')
C:/Users/qus/.platformio/packages/framework-espidf/tools/cmake/project.cmake:447 (idf_build_process)
CMakeLists.txt:4 (project)
========================= [FAILED] Took 12.71 seconds =========================
Environment Status Duration
iec-nugget FAILED 00:00:12.708
==================== 1 failed, 0 succeeded in 00:00:12.708 ====================
