Actually the options should come after the publish command and then the file name. Have you tried
pio package publish --owner asukiaaa --released-at "2020-04-29 14:09:00" 1.0.0.zip
No difference with using the command.
File "/home/asuki/.local/lib/python3.8/site-packages/platformio/__main__.py", line 109, in main
File "/home/asuki/.local/lib/python3.8/site-packages/click/core.py", line 829, in __call__
File "/home/asuki/.local/lib/python3.8/site-packages/click/core.py", line 782, in main
rv = self.invoke(ctx)
File "/home/asuki/.local/lib/python3.8/site-packages/platformio/commands/__init__.py", line 44, in invoke
return super(PlatformioCLI, self).invoke(ctx)
File "/home/asuki/.local/lib/python3.8/site-packages/click/core.py", line 1259, in invoke
File "/home/asuki/.local/lib/python3.8/site-packages/click/core.py", line 1066, in invoke
File "/home/asuki/.local/lib/python3.8/site-packages/click/core.py", line 610, in invoke
return callback(*args, **kwargs)
File "/home/asuki/.local/lib/python3.8/site-packages/platformio/commands/package.py", line 87, in package_publish
archive_path = p.pack()
File "/home/asuki/.local/lib/python3.8/site-packages/platformio/package/pack.py", line 120, in pack
with FileUnpacker(src) as fu:
File "/home/asuki/.local/lib/python3.8/site-packages/platformio/package/unpack.py", line 152, in __enter__
self._archiver = self._init_archiver()
File "/home/asuki/.local/lib/python3.8/site-packages/platformio/package/unpack.py", line 144, in _init_archiver
with open(self.path, "rb") as fp:
FileNotFoundError: [Errno 2] No such file or directory: '1.0.0.zip'
`pip install -U platformio` command
https://docs.platformio.org/page/faq.html
What in theā¦ ls
returns the file name and you execute the command in the same terminal session right?
Hm the only other thing I could think of is if it requires an absolute path. Can you try
pio package publish --owner asukiaaa --released-at "2020-04-29 14:09:00" $PWD/1.0.0.zip
Thank you for the information.
I got other error with using $PWD for path.
Error: You do not have permission to set custom released date for a public package (library)
Iām sure thad I have logged in.
pio account show
Profile
Username: asukiaaa
Email: asukiaaa@gmail.com
First name: Asuki
Last name: Kono
Packages
Remote Development for Developer
Forever Free Remote Development for an awesome PlatformIO Community
Expire: -
Services: 100 Concurrent Remote Agents, 100 Shares per Remote Agent, Remote Unit Testing (100,000 sessions per month), Remote Serial Port Monitor (50,000 sessions per month), Remote Device Manager, Remote Firmware Updates (100,000 per month)
Trusted Registry for Developer
Forever Free Trusted Registry for an awesome PlatformIO Community
Expire: -
Services: Publish a public development platform (max. size 50MB), Unpublish a pushed package or version in 72h, Publish a public tool (framework, SDK, toolchain, upload and debug tools, etc.) (max. size 500MB), Automatic moderation for a public library, Publish a public library (max. size 50MB)
Do you know who has permission to specify released_at.
@ivankravets will need to clarify what is going on here.
I believe that the issue is that the error is misleading and the real issue is that you did not add the library to the registry, and is a ālegacyā library, hence the mention of āpublic package (library)ā. This is just a guess though, and if it is the case, I donāt know what the process of resolving it will be.
I would have thought it would changing things like released_at
would have been fine if you are the owner of the library though.
Maybe try pio access list asukiaaa
to see if it recognises that you are the library owner and have admin access to manage it? If I run that command, I get āYou do not have any resources.ā so either that is indeed the issue, or it only works for that user.
e.g. I havenāt tried to do what you have done, but I get
pio access list pfeerick
elapsedMillis
URN: prn:reg:pkg:1002:library
Owner: pfeerick
Access level(s): Admin
I may have admin permission for utils_asukiaaa
Do you think that I can specify released_at
because I am admin of utils_asukiaaa
SomeSerial
URN: prn:reg:pkg:1274:library
Owner: asukiaaa
MPU9250_asukiaaa
URN: prn:reg:pkg:1751:library
Owner: asukiaaa
AM2320_asukiaaa
URN: prn:reg:pkg:5850:library
Owner: asukiaaa
EPD
URN: prn:reg:pkg:6033:library
Owner: asukiaaa
ST7032_asukiaaa
URN: prn:reg:pkg:6185:library
Owner: asukiaaa
BLVD20KM_asukiaaa
URN: prn:reg:pkg:6499:library
Owner: asukiaaa
ThingSpeak_asukiaaa
URN: prn:reg:pkg:6503:library
Owner: asukiaaa
WiredController_asukiaaa
URN: prn:reg:pkg:6564:library
Owner: asukiaaa
INA226_asukiaaa
URN: prn:reg:pkg:6774:library
Owner: asukiaaa
AD5254_asukiaaa
URN: prn:reg:pkg:6808:library
Owner: asukiaaa
I2cMotors_asukiaaa
URN: prn:reg:pkg:7133:library
Owner: asukiaaa
utils_asukiaaa
URN: prn:reg:pkg:7286:library
Owner: asukiaaa
I2cControlPanel_asukiaaa
URN: prn:reg:pkg:11105:library
Owner: asukiaaa
I2cMultipleMotors_asukiaaa
URN: prn:reg:pkg:11182:library
Owner: asukiaaa
rs485_asukiaaa
URN: prn:reg:pkg:11270:library
Owner: asukiaaa
button_asukiaaa
URN: prn:reg:pkg:11271:library
Owner: asukiaaa
wire_asukiaaa
URN: prn:reg:pkg:11277:library
Owner: asukiaaa
string_asukiaaa
URN: prn:reg:pkg:11278:library
Owner: asukiaaa
Hmā¦ I got nothingā¦ I would have thought since it says you have admin access to that library it would workā¦ Youāll have to wait for Ivan to respond on that one, I canāt be of more help on that front.
I see.
Thank you for a lot of information.
I wait response.
Yes, this option is available for super admins. We donāt allow users to use custom release date.
I see, thank you for the information.
