I have developed a custom board using an STM32F411VET6, and I am having issues with getting everything working properly on the board. I found a similar board, and modified it. It works, but there are two issues. One is just minor, but one is a show stopper.
The minor issue is that all pins >PB_11 are off by one. I can deal with that. A more major issue for me is that I am having major issues with with interrupts on pin state change. Essentially, I want to have interrupts on state change of 16 pins.
If I use the following code, it works… It is operating on PE_1.
stm32_interrupt_enable((GPIO_TypeDef *)GPIOE_BASE, GPIO_PIN_1, pinStateChanged_A0, GPIO_MODE_IT_RISING_FALLING);
If I then use the following code, the previous interrupt stops working, and this newer one works.
stm32_interrupt_enable((GPIO_TypeDef *)GPIOD_BASE, GPIO_PIN_1, pinStateChanged_C1, GPIO_MODE_IT_RISING_FALLING);
Here is the relevant part of my platformio.ini file
[env:AlarmOctopus_pcbv1]
platform = ststm32
board = generic
platform_packages = toolchain-gccarmnoneeabi@1.90201.191206
This points to the following generic.json file
"build": {
"core": "stm32",
"cpu": "cortex-m4",
"extra_flags": "-DSTM32F411xE -DSTM32F4xx -DARDUINO_GENERIC_F411VETX ",
"f_cpu": "100000000L",
"mcu": "stm32f411vet6",
"product_line": "STM32F411xE",
"variant": "STM32F4xx/F411V(C-E)T"
"debug": {
"jlink_device": "STM32F411VE",
"openocd_target": "stm32f4x",
"svd_path": "STM32F411xx.svd"
"frameworks": [
"arduino",
"cmsis",
"stm32cube",
"libopencm3"
"name": "STM32F411VE (128k RAM. 512k Flash)",
"upload": {
"maximum_ram_size": 131072,
"maximum_size": 524288,
"protocol": "stlink",
"protocols": [
"blackmagic",
"dfu",
"jlink",
"serial",
"stlink"
"url": "https://www.st.com/en/microcontrollers-microprocessors/stm32f411re.html",
"vendor": "Generic"
To get this to work, I needed to generate a ldscript.ld using STM32Cube and place it in .platformio/packages/framework-arduinoststm32/variants/STM32F4xx/F411V(C-E)T. Like I noted, the only issues I am seeing are with pin numbering and interrupts.
EDIT: If I use something like attachInterrupt(digitalPinToInterrupt(reader[2].in_D1), pinStateChanged_C1, CHANGE); I am still getting exactly the same issue. From further reading, there are a limited number of hardware interrupts; and it appears that all the 0 pins (PA_0, PB_0, …) should share the same interrupt. So should all the 1 pins (PA_1, PB_2, …) and so forth. It further appears that the software architecture should be rather smart, and then forward the hardware interrupts on. I have no idea why the latest attachInterrupt for a pin set is the only one that is working.
Any assistance would be appreciated. Thanks.
