Intermittent GDB problems with PIO 6.1.1 under Windows
Hi all
Trying to debug a new ESP32 project using proprietary hardware and esp-prog I could not start a GDB-session. After numerous trials and failures I reverted to this very basic scenario, but still no success: I created a new Arduino project using an ESP-Wrover-Kit V4.1. This is platformio.ini:
[env:esp-wrover-kit]
board = esp-wrover-kit
debug_speed = 500
and this is the Arduino code, straight from PIO:
// put function declarations here:
int myFunction(int, int);
  int result = myFunction(2, 3);
// put function definitions here:
int myFunction(int x, int y) {
  return x + y;
Then I hit F5. Compilation in debug mode alsways works without errors, then GDB comes up. Sometimes execution stops at the entry of setup(), as expected. But mostly I get this on the Debug Console:
undefinedC:\Users\Peter\.platformio\packages\toolchain-xtensa-esp32\bin\xtensa-esp32-elf-gdb.exe: warning: Couldn't determine a path for the index cache directory.
Reading symbols from D:\Peter\Documents\PlatformIO\Projects\dbg-Doodle\.pio\build\esp-wrover-kit\firmware.elf...
PlatformIO: debug_tool = ftdi
Open On-Chip Debugger  v0.11.0-esp32-20220706 (2022-07-06-15:48)
Licensed under GNU GPL v2
For bug reports, read
adapter speed: 20000 kHz
WARNING: boards/esp32-wrover.cfg is deprecated, and may be removed in a future release.
         If your board is ESP32-WROVER-KIT, use board/esp32-wrover-kit-1.8v.cfg instead.
adapter speed: 500 kHz
Info : tcl server disabled
Info : telnet server disabled
Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Info : clock speed 500 kHz
Info : [esp32.cpu0] Target halted, PC=0x4000C341, debug_reason=00000000
Info : [esp32.cpu1] Target halted, PC=0x40000400, debug_reason=00000000
Info : starting gdb server for esp32.cpu0 on pipe
Warn : No symbols for FreeRTOS!
Info : [esp32.cpu0] Target halted, PC=0x40092612, debug_reason=00000001
Info : Set GDB target to 'esp32.cpu0'
Info : Flash mapping 0: 0x10020 -> 0x3f400020, 103 KB
Info : Flash mapping 1: 0x30020 -> 0x400d0020, 543 KB
Info : Auto-detected flash bank 'esp32.cpu0.flash' size 4096 KB
Info : Using flash bank 'esp32.cpu0.flash' size 4096 KB
Info : Using flash bank 'esp32.cpu0.irom' size 544 KB
Info : Using flash bank 'esp32.cpu0.drom' size 104 KB
Info : New GDB Connection: 1, Target esp32.cpu0, state: halted
Warn : negative reply, retrying
0x4000c341 in ?? ()
Info : [esp32.cpu0] requesting target halt and executing a soft reset
Info : [esp32.cpu0] Debug controller was reset.
Info : [esp32.cpu0] Core was reset.
Info : [esp32.cpu0] Target halted, PC=0x500000CF, debug_reason=00000000
Info : [esp32.cpu1] requesting target halt and executing a soft reset
Info : [esp32.cpu0] Target halted, PC=0x40000400, debug_reason=00000000
Info : [esp32.cpu1] Debug controller was reset.
Info : [esp32.cpu1] Core was reset.
Info : Auto-detected flash bank 'esp32.cpu1.flash' size 4096 KB
Info : Using flash bank 'esp32.cpu1.flash' size 4096 KB
** Programming Started **
Error: timed out while waiting for target halted
Error: xtensa_wait_algorithm: not halted 0, pc 0x4000c341, ps 0x60025
Error: Failed to wait algorithm (-302)!
Error: Algorithm run failed (-302)!
Error: Target is already running an algorithm
Error: Failed to start algorithm (-4)!
Info : PROF: Erased 20480 bytes in 767.782 ms
Info : PROF: Wrote 20480 bytes in 777.328 ms (data transfer time included)
** Programming Finished in 44632 ms **
** Verify Started **
Info : PROF: Flash verified in 777.196 ms
Error: **** Verification failure! ****
Error: target_hash fcef9e...000
Error: file_hash: a1108e...9dcd9c
** Verify Failed **
.pioinit:12: Error in sourced command file:
Protocol error with Rcmd
  • What algorithm is the target alredy running?
  • And why is there a verification failure? I tried to alleviate communication problems by reducing the debug speed to 500 kHz.
  • And what can I do to avoid this: WARNING: boards/esp32-wrover.cfg is deprecated, and may be removed in a future release.
    Thank you for your help!
