I have 2 external libraries, library1 and library2. Library2 depends on some source files from library1.
However, library1 has its source code files located inside a /lib folder, and /src holds javascript code that generates the .h and .cpp files that are inside of /lib. Compiling the whole project will result in “No such file or directory error”.
If I move all of the source code from /lib into /src inside of library1, library2 will see these files and compiling will be OK. My question is how can I include the /lib folder inside of library1 as part of its source so that library2 can see it? (I’ve also tried using “srcFilter” param but doesn’t seem to work)
Project tree
|----<.piolibdeps> | |----<library1/> | | |----<lib/> | | | |----<subfolder> | | | | |----file.h | | | | |----file.cpp | | |----<src/> | | | |----javascript.js | |----<library2/> | | |----<src> | | |----file2.h // <--- includes <file.h> in library1/lib/subfolder | | |----file2.cpp |----<src/> | |----main.cpp
library1’s library.json
... "build": { "srcFilter": [ "+<../lib/subfolder/*.c>", "+<../lib/subfolder/*.cpp>", "+<../lib/subfolder/*.h>" ] }, ...
lib_deps
lib_deps = git@github.com:placesss/library1.git git@github.com:placesss/library2.git
