I seem to not to be alone with this annoying Intellisense “feature”, but found no solution yet:
This class definition
class PushClient
protected:
struct {
uint8_t _slaveID;
uint16_t _addr;
uint16_t _wrds;
uint8_t *_data;
uint8_t _result;
} _comp[PCOMPONENTS]; // up to PCOMPONENTS single requests are possible
(the rest is unimportant)
is forcing Intellisense to complain wherever a line using the _comp struct is found, like
_comp[inx]._result = 0xE5; // DATA error
resulting in
no operator "[]" matches these operands -- operand types are: struct PushClient::<unnamed> [ uint8_t ]
This effect does vanish occasionally, but most of the time the squiggles and problem messages are there. The code is C+±compliant, of course and compiles just fine. I got some dozens of these lines, so the problem message task window is flooded with the silly messages.
I dug the C++11 references to find a clue and happened to find one:
17.4.3.1.2 Global names [lib.global.names]
Certain sets of names and function signatures are always reserved to the implementation:
Each name that contains a double underscore ( __ ) or begins with an underscore followed by an uppercase letter (2.11) is reserved to the implementation for any use.
Each name that begins with an underscore is reserved to the implementation for use as a name in the global namespace.165
Such names are also reserved in namespace ::std (17.4.3.1).
And indeed when renaming the _comp to just comp the issue seems to be gone.
