VSC 1.42.0, Platfomio Home 3.0.1, Core 4.1.0, Mac OS-X 10.13.6
Installed extensions C/C++ Intellisense 0.26.3, C++ Intellisense 0.2.2 and Platformio IDE 1.10.0.
(Both the above Intellisenses are recommended, does that mean I need both?)
I have an Atmel 2560 project, about 10,000 lines spread over 22 source and 25 include files. Developing on Arduino Mega (and Veroboard!), also have final 2561 version on custom PCB.
The project compiles and runs (both CPUs).
When I open one particular file (just happens to be the largest) I get 11 āProblemsā for 3 identiers, all are of the type 'identifier āLCD_LINE_LENā. āLCD_LINE_LENā occurs 180 times in this file
Intellisense does all the right things, I can goto Definitions, Declarations etc., even for the light bulbed āundefinedā identifiers.
I have a top level workspace with a .vscode dir, projects opened from Platformio Home open in the top level workspace, with their own .vscode dir. The c_cpp_properties.json files appear to be set up to compile for Mac, that confuses me a bit.
Iāve tried many things suggested in the forum, adding build flags, adding include lines to Intellisense config, but canāt get rid of the 11 problems.
Can anyone help with this?
Thanks in advance, Ken
You should not activate any additional C/C++ related extensions except:
- PlatformIO IDE by PlatformIO
- C/C++ by Microsoft
Itās the expected behavior to have a configuration called Mac if youāre running Visual Studio Code on macOS. So no worries.
But you will need to provide more information so we can reproduce it:
- Can you share the project (e.g. on GitHub)?
- What are the detailed error messages?
At least try the following steps:
- Restart Visual Studio Code
- Rebuild the IntelliSense Index (View / Command Palette⦠/ PlatformIO: Rebuild IntelliSense Index)
- Make sure the PlatformIO project is open in Visual Studio Code and the problematic file has been opened from the Explorer view (and not from an error message in the terminal)
Hi Manuel and thanks for your reply.
Removed the extra intellisense extension.
Not keen on sharing this part complete project on GitHub but Iāll do a bit of work on cutting it down to something that shows the problem and share that.
The āProblemā messages are all of the type:
identifier āRPM_CORRECT_NONEā is undefined [line, col]
identifier āRPM_CORRECT_FULLā is undefined [line, col]
identifier āLCD_LINE_LENā is undefined [line, col]
identifier āLOOP_OF_DEATHā is undefined [line, col]
[line, col] are numeric values
All the problem identifiers are in include files and the project compiles and runs.
At times I also get include errors for the 22 .h files included by the problem file, all of the type:
cannot open source file āads.hā C/C++(1696) [line, col]
cannot open source file ātimer0_pwm.hā C/C++(1696) [line, col]
cannot open source file āee_prom.hā C/C++(1696) [line, col]
These include errors come and go and I donāt know what action makes them disappear.
Iāve tried your suggestions, following your steps exactly with no change. Also tried ācodeā in a terminal, removing the projects from the workspace and re-adding them with no success.
