Hi All,
I have a funny issue, it is more of an irritation than and issue. my code compiles and works but the intellisence that highlights the code / variables makes it all white as apposed to like it did.
It seems like it more of the variables and not so much the functions, I cannot see any upgrades that might have caused this and also cant find a related post of this nature.
Please advise if anyone has seen and repaired this before?
Kind Regards,
Jonathan
Hi Maxgerhardt,
Please see the responses below,
- This is a project created from scratch in VSCode / PlatformIO it was not imported.
- Yes I have rebuild the intellisense BD,
- Yes they are .CPP
I have attached another screen print to explain,
As you can see at the top I have two arrays in the strcpy function they appear white, then the lie below I set a single char in that array to ‘B’ but the color of the variable is fine light blue as it was since I installed the application.
further down another sample, Adress[12] appears fine but the next variable indx1 is white again.
I am not sure why this is happening, I have reinstalled PlatformIO and the C++ extension it had installed, I even reinstalled VSCODE but no luck.
Hope I can get it resolved,
J
