I created a project using CubeMX with the Makefile option, and I can successfully build and upload the code with the following platformio.ini file. Up to this point everything works fine:
[platformio]
src_dir = Core/Src ; path for main.h
[env:genericSTM32F103C8]
platform = ststm32
board = genericSTM32F103C8
framework = stm32cube
; Programmer
upload_protocol = stlink
debug_tool = stlink
-I Core/Inc
-I Drivers/STM32F1xx_HAL_Driver/Inc
-I Drivers/STM32F1xx_HAL_Driver/Inc/Legacy
-I Drivers/CMSIS/Device/ST/STM32F1xx/Include
-I Drivers/CMSIS/Include
-I USB_DEVICE/App
-I USB_DEVICE/Target
-I Middlewares/ST/STM32_USB_Device_Library/Core/Inc
-D USE_HAL_DRIVER
-D HSE_VALUE=8000000U
However, when I enable USB in CubeMX, it generates the USB_DEVICE folder at the project root instead of inside Core/Src.
Similarly, the Drivers and Middlewares folders are also placed at the project root.
During the build process I could not manage to properly include these files. I tried several different approaches but none of them worked.
Is there a current recommended way / workflow to integrate CubeMX-generated code (with USB enabled, Drivers, and Middlewares at root level) into PlatformIO?
