Hi there,
I started a project in Arduino IDE and switched to platformIO because I had problems to achieve a clean structure in Arduino IDE.
I’m using several 3rd party libraries which are available in the Arduino library manager.
For example “neotimer”. I installed it in platformIO and this worked.
But now I have a problem I do not understand.
I have a main.cpp, which includes some header files, also I have added some cpp files:
main.cpp:
#include "Any1.h"
#include "Any2.h"
Function1();
Function3();
Function2();
Function4();
Any1.cpp:
#include <Neotimer.h>
#include "Any1.h"
#include "Any2.h"
Neotimer MyTimer1 = Neotimer();
void Function1 ( void )
MyTimer1.set(100);
MyTimer1.start();
void Function2 ( void )
if (MyTimer1.done())
MyTimer1.reset();
Any2.cpp:
#include "Any1.h"
#include "Any2.h"
Neotimer MyTimer2 = Neotimer();
void Function3 ( void )
MyTimer2.set(100);
MyTimer2.start();
void Function4 ( void )
if (MyTimer2.done())
MyTimer2.reset();
Any1.h:
#ifndef ANY1_H
#define ANY1_H
void Function1 ( void );
void Function2 ( void );
Any2.h:
#ifndef ANY2_H
#define ANY2_H
void Function3 ( void );
void Function4 ( void );
Don’t wonder if this makes sense, this is just a simple sample to show my problem.
The problem is now, that the compiler fails, and I have absolutelty no idea why:
Compiling .pio\build\esp32dev\src\main.cpp.o
Archiving .pio\build\esp32dev\libFrameworkArduino.a
Linking .pio\build\esp32dev\firmware.elf
.pio\build\esp32dev\src\Any2.cpp.o: In function `Neotimer::Neotimer()':
D:\users\xxxx\Documents\PlatformIO\Projects\DebuggingProject/.pio\libdeps\esp32dev\Neotimer\src/Neotimer.h:48: multiple definition of `Neotimer::Neotimer()'
.pio\build\esp32dev\src\Any1.cpp.o:D:\users\xxxx\Documents\PlatformIO\Projects\DebuggingProject/.pio\libdeps\esp32dev\Neotimer\src/Neotimer.h:48: first defined here
Any2.cpp:(.text._ZN8NeotimerC2Ev+0x0): multiple definition of `Neotimer::Neotimer()'
.pio\build\esp32dev\src\Any1.cpp.o:Any1.cpp:(.text._ZN8NeotimerC2Ev+0x0): first defined here
.pio\build\esp32dev\src\Any2.cpp.o: In function `Neotimer::Neotimer(long)':
Any2.cpp:(.text._ZN8NeotimerC2El+0x0): multiple definition of `Neotimer::Neotimer(long)'
.pio\build\esp32dev\src\Any1.cpp.o:Any1.cpp:(.text._ZN8NeotimerC2El+0x0): first defined here
.pio\build\esp32dev\src\Any2.cpp.o: In function `Neotimer::~Neotimer()':
Any2.cpp:(.text._ZN8NeotimerD2Ev+0x0): multiple definition of `Neotimer::~Neotimer()'
.pio\build\esp32dev\src\Any1.cpp.o:Any1.cpp:(.text._ZN8NeotimerD2Ev+0x0): first defined here
.pio\build\esp32dev\src\Any2.cpp.o: In function `Neotimer::init()':
Any2.cpp:(.text._ZN8Neotimer4initEv+0x0): multiple definition of `Neotimer::init()'
.pio\build\esp32dev\src\Any1.cpp.o:Any1.cpp:(.text._ZN8Neotimer4initEv+0x0): first defined here
.pio\build\esp32dev\src\Any2.cpp.o: In function `Neotimer::repeatReset()':
Any2.cpp:(.text._ZN8Neotimer11repeatResetEv+0x0): multiple definition of `Neotimer::repeatReset()'
.pio\build\esp32dev\src\Any1.cpp.o:Any1.cpp:(.text._ZN8Neotimer11repeatResetEv+0x0): first defined here
.pio\build\esp32dev\src\Any2.cpp.o: In function `Neotimer::done()':
Any2.cpp:(.text._ZN8Neotimer4doneEv+0x0): multiple definition of `Neotimer::done()'
.pio\build\esp32dev\src\Any1.cpp.o:Any1.cpp:(.text._ZN8Neotimer4doneEv+0x0): first defined here
.pio\build\esp32dev\src\Any2.cpp.o: In function `Neotimer::set(long)':
Any2.cpp:(.text._ZN8Neotimer3setEl+0x0): multiple definition of `Neotimer::set(long)'
.pio\build\esp32dev\src\Any1.cpp.o:Any1.cpp:(.text._ZN8Neotimer3setEl+0x0): first defined here
.pio\build\esp32dev\src\Any2.cpp.o: In function `Neotimer::get()':
Any2.cpp:(.text._ZN8Neotimer3getEv+0x0): multiple definition of `Neotimer::get()'
.pio\build\esp32dev\src\Any1.cpp.o:Any1.cpp:(.text._ZN8Neotimer3getEv+0x0): first defined here
.pio\build\esp32dev\src\Any2.cpp.o: In function `Neotimer::stop()':
Any2.cpp:(.text._ZN8Neotimer4stopEv+0x0): multiple definition of `Neotimer::stop()'
.pio\build\esp32dev\src\Any1.cpp.o:Any1.cpp:(.text._ZN8Neotimer4stopEv+0x0): first defined here
.pio\build\esp32dev\src\Any2.cpp.o: In function `Neotimer::reset()':
Any2.cpp:(.text._ZN8Neotimer5resetEv+0x0): multiple definition of `Neotimer::reset()'
.pio\build\esp32dev\src\Any1.cpp.o:Any1.cpp:(.text._ZN8Neotimer5resetEv+0x0): first defined here
.pio\build\esp32dev\src\Any2.cpp.o: In function `Neotimer::repeat()':
Any2.cpp:(.text._ZN8Neotimer6repeatEv+0x0): multiple definition of `Neotimer::repeat()'
.pio\build\esp32dev\src\Any1.cpp.o:Any1.cpp:(.text._ZN8Neotimer6repeatEv+0x0): first defined here
.pio\build\esp32dev\src\Any2.cpp.o: In function `Neotimer::repeat(int)':
Any2.cpp:(.text._ZN8Neotimer6repeatEi+0x0): multiple definition of `Neotimer::repeat(int)'
.pio\build\esp32dev\src\Any1.cpp.o:Any1.cpp:(.text._ZN8Neotimer6repeatEi+0x0): first defined here
.pio\build\esp32dev\src\Any2.cpp.o: In function `Neotimer::repeat(int, long)':
Any2.cpp:(.text._ZN8Neotimer6repeatEil+0x0): multiple definition of `Neotimer::repeat(int, long)'
.pio\build\esp32dev\src\Any1.cpp.o:Any1.cpp:(.text._ZN8Neotimer6repeatEil+0x0): first defined here
.pio\build\esp32dev\src\Any2.cpp.o: In function `Neotimer::start()':
Any2.cpp:(.text._ZN8Neotimer5startEv+0x0): multiple definition of `Neotimer::start()'
.pio\build\esp32dev\src\Any1.cpp.o:Any1.cpp:(.text._ZN8Neotimer5startEv+0x0): first defined here
.pio\build\esp32dev\src\Any2.cpp.o: In function `Neotimer::debounce(bool)':
Any2.cpp:(.text._ZN8Neotimer8debounceEb+0x0): multiple definition of `Neotimer::debounce(bool)'
.pio\build\esp32dev\src\Any1.cpp.o:Any1.cpp:(.text._ZN8Neotimer8debounceEb+0x0): first defined here
.pio\build\esp32dev\src\Any2.cpp.o: In function `Neotimer::restart()':
Any2.cpp:(.text._ZN8Neotimer7restartEv+0x0): multiple definition of `Neotimer::restart()'
.pio\build\esp32dev\src\Any1.cpp.o:Any1.cpp:(.text._ZN8Neotimer7restartEv+0x0): first defined here
.pio\build\esp32dev\src\Any2.cpp.o: In function `Neotimer::waiting()':
Any2.cpp:(.text._ZN8Neotimer7waitingEv+0x0): multiple definition of `Neotimer::waiting()'
.pio\build\esp32dev\src\Any1.cpp.o:Any1.cpp:(.text._ZN8Neotimer7waitingEv+0x0): first defined here
.pio\build\esp32dev\src\Any2.cpp.o: In function `Neotimer::started()':
Any2.cpp:(.text._ZN8Neotimer7startedEv+0x0): multiple definition of `Neotimer::started()'
.pio\build\esp32dev\src\Any1.cpp.o:Any1.cpp:(.text._ZN8Neotimer7startedEv+0x0): first defined here
*** [.pio\build\esp32dev\firmware.elf] Error 1
Can anyone give me a hint what I’m doing wrong?
Is this Neotimer library not able to be used in 2 cpps at the same time?
