Installing latest Arduino framework for ESP32 (3.0.x) will crash
Hi all,
I’m following these instructions to use the latest 3.0.1 release of the ESP32 arduino framwork for PlatformIO, but this crashes upon install. The same happens if I specify in my platformio.ini file to use version 3.0.1 of arduino-esp32.
To reproduce, just use this config in platformio.ini:
; Redirecting...
[env:adafruit_feather_esp32s3_nopsram]
board = adafruit_feather_esp32s3_nopsram
build_flags = -DARDUINO_USB_MODE=1
platform_packages =
    platformio/framework-arduinoespressif32 @ https://github.com/espressif/arduino-esp32.git
Upon installing, the installer/build script will crash with the following Python error:
Resolving adafruit_feather_esp32s3_nopsram dependencies...
Already up-to-date.
Updating metadata for the vscode IDE...
UserSideException: Processing adafruit_feather_esp32s3_nopsram (platform: espressif32; board: adafruit_feather_esp32s3_nopsram; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/adafruit_feather_esp32s3_nopsram.html
PLATFORM: Espressif 32 (6.7.0) > Adafruit Feather ESP32-S3 No PSRAM
HARDWARE: ESP32S3 240MHz, 320KB RAM, 8MB Flash
DEBUG: Current (cmsis-dap) External (cmsis-dap, esp-bridge, esp-builtin, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
 - framework-arduinoespressif32 @ 3.0.1+sha.6b22339
 - toolchain-riscv32-esp @ 12.2.0+20230208
 - toolchain-xtensa-esp32s3 @ 12.2.0+20230208
KeyError: 'framework-arduinoespressif32-libs':
  File "/Users/jensa/.platformio/penv/lib/python3.11/site-packages/platformio/builder/main.py", line 173:
  File "/Users/jensa/.platformio/packages/tool-scons/scons-local-4.7.0/SCons/Script/SConscript.py", line 612:
  File "/Users/jensa/.platformio/packages/tool-scons/scons-local-4.7.0/SCons/Script/SConscript.py", line 279:
  File "/Users/jensa/.platformio/platforms/espressif32/builder/main.py", line 368:
  File "/Users/jensa/.platformio/packages/tool-scons/scons-local-4.7.0/SCons/Util/envs.py", line 251:
  File "/Users/jensa/.platformio/penv/lib/python3.11/site-packages/platformio/builder/tools/piobuild.py", line 61:
    env.ProcessProgramDeps()
  File "/Users/jensa/.platformio/penv/lib/python3.11/site-packages/platformio/builder/tools/piobuild.py", line 121:
  File "/Users/jensa/.platformio/penv/lib/python3.11/site-packages/platformio/builder/tools/piobuild.py", line 347:
    SConscript(env.GetFrameworkScript(name), exports="env")
  File "/Users/jensa/.platformio/packages/tool-scons/scons-local-4.7.0/SCons/Script/SConscript.py", line 676:
    return method(*args, **kw)
  File "/Users/jensa/.platformio/platforms/espressif32/builder/frameworks/arduino.py", line 36:
    SConscript(
  File "/Users/jensa/.platformio/packages/framework-arduinoespressif32@src-537c58760dafe7fcc8a1d9bbcf00b6f6/tools/platformio-build.py", line 38:
    FRAMEWORK_LIBS_DIR = platform.get_package_dir("framework-arduinoespressif32-libs")
  File "/Users/jensa/.platformio/penv/lib/python3.11/site-packages/platformio/platform/_packages.py", line 32:
    pkg = self.get_package(name)
  File "/Users/jensa/.platformio/penv/lib/python3.11/site-packages/platformio/platform/_packages.py", line 29:
    return self.pm.get_package(spec or self.get_package_spec(name))
  File "/Users/jensa/.platformio/penv/lib/python3.11/site-packages/platformio/platform/_packages.py", line 21:
    owner=self.packages[name].get("owner"),
========================== [FAILED] Took 0.61 seconds ==========================
I have tried to manually deleted all folders with the name “framework-arduinoespressif32” from my /Users/name/.platformio/packages This obviously makes the install take longer, but it still will exit with the same errors. I’m on macOS 13.1, with all updates applied in PlatformIO ( Core 6.1.15, Home 3.4.4, EspressIF 6.7.0).
It looks like it’s just a variable that is incorrectly defined for the library path, but Python really isn’t my strong side… Any advice appreciated!
See Can't get esp32-arduino 3.0.0rc1 installed - #4 by bcsabadiy
