Install VScode Platformio win10
Hi
i updated my system from win7 to win10.
I used before Atom & Platformio
now i install all new and install VScode and Platformio-
I get now some problems with my libs
Thats my platformio.ini
[env:megaatmega2560]
board = megaatmega2560
    paulstoffregen/Time@^1.6
    sodaqmoja/Sodaq_SHT2x@^1.2.0
    arduino-libraries/Ethernet@^2.0.0
    paulstoffregen/OneWire@^2.3.5
    milesburton/DallasTemperature@^3.9.1
    adafruit/RTClib@^1.12.4
    thomasfredericks/Bounce2@^2.55
    paulstoffregen/TimeAlarms@0.0.0-alpha+sha.c291c1ddad
    chuckbell/MySQL Connector Arduino@^1.2.0
    https://github.com/rambo/I2C.git
lib_deps_external =
[env:myenv]
lib_extra_dirs =
    C:\Users\a2106\Documents\PlatformIO\Projects\ext-libs
when i compile my program then i get some errors
Warning! Ignore unknown configuration option `lib_deps_external` in section [env:megaatmega2560]
----------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/megaatmega2560.html
PLATFORM: Atmel AVR (3.0.0) > Arduino Mega or Mega 2560 ATmega2560 (Mega 2560)
 - framework-arduino-avr 5.1.0
Converting grobot-25-12-2020.ino
Library Manager: Installing git+https://github.com/rambo/I2C.git
UserSideException: Please install Git client from https://git-scm.com/downloads:
  File "C:\Users\a2106\.platformio\penv\lib\site-packages\platformio\builder\main.py", line 170:
  File "C:\Users\a2106\.platformio\packages\tool-scons\scons-local-4.0.1\SCons\Script\SConscript.py", line 598:
  File "C:\Users\a2106\.platformio\packages\tool-scons\scons-local-4.0.1\SCons\Script\SConscript.py", line 287:
  File "C:\Users\a2106\.platformio\platforms\atmelavr\builder\main.py", line 162:
  File "C:\Users\a2106\.platformio\packages\tool-scons\scons-local-4.0.1\SCons\Environment.py", line 219:
  File "C:\Users\a2106\.platformio\penv\lib\site-packages\platformio\builder\tools\platformio.py", line 62:
    env.ProcessProjectDeps()
  File "C:\Users\a2106\.platformio\penv\lib\site-packages\platformio\builder\tools\platformio.py", line 140:
    project_lib_builder = env.ConfigureProjectLibBuilder()
  File "C:\Users\a2106\.platformio\penv\lib\site-packages\platformio\builder\tools\piolib.py", line 1062:
    project.install_dependencies()
  File "C:\Users\a2106\.platformio\penv\lib\site-packages\platformio\builder\tools\piolib.py", line 898:
    lm.install(spec)
  File "c:\users\a2106\.platformio\penv\lib\site-packages\platformio\package\manager\_install.py", line 49:
    spec, silent=silent, skip_dependencies=skip_dependencies, force=force
  File "c:\users\a2106\.platformio\penv\lib\site-packages\platformio\package\manager\library.py", line 86:
    force=force,
  File "c:\users\a2106\.platformio\penv\lib\site-packages\platformio\package\manager\_install.py", line 97:
    pkg = self.install_from_url(spec.url, spec, silent=silent)
  File "c:\users\a2106\.platformio\penv\lib\site-packages\platformio\package\manager\_install.py", line 141:
    vcs = VCSClientFactory.new(tmp_dir, url)
  File "c:\users\a2106\.platformio\penv\lib\site-packages\platformio\package\vcsclient.py", line 55:
    src_dir, remote_url, tag, silent
  File "c:\users\a2106\.platformio\penv\lib\site-packages\platformio\package\vcsclient.py", line 72:
    self.check_client()
  File "c:\users\a2106\.platformio\penv\lib\site-packages\platformio\package\vcsclient.py", line 138:
    "Please install Git client from https://git-scm.com/downloads"
if i install with win10 the Git Client
no helps
what is wrong
can anybody help?
Regards
Achim
Have you restarted your computer already? So that the changes to PATH take effect for sure.
Please also open a terminal (Windows + R --> cmd.exe) and execute git --version. Does it return a sensible version info or “Command not found”?
As a last thing, you can also uninstall and re-install the VSCode PlatformIO extension.
thanks so much
only restart
Thank YOU
