Install platformio in different folder on Linux
I’m creating a jenkins docker image that contains platformio intallation. By default the installation is run as user jenkins and this will install platformio in /var/jenkins_home/.platformio.
But when running a jenkins container the /var/jenkins_home folder is usually bound to an external volume which will of course hide the original folder in the image.
Is it possible to have get-platformio.py install platformio in a configurable folder?
@ivankravets I think you should have a look at that question
You need Environment variables — PlatformIO latest documentation
Happy coding with PlatformIO!
So do I understand correctly that you first set PLATFORM_CORE_DIR env variable and then call python get-platformio.py ?
I tried it but it doesn’t work, its still installed in /var/jenkins_home
I’m also interesting to specify install directory but on Windows10.
Especially because i’m using esp-idf which doesn’t accept spaces in build names.
I have a space in my windows user directory and cannot change it as i’m not an administrator.
I have also tried the core dir option in my platformio.ini file of the corresponding project but pio is still launch from “c:\users<username with space>.platformio\penv\scripts\python.exe”
I tried to manually move the whole directory in an another place and then change my PATH settings to point on the new folder but the command line python get-platformio.py check core doesn’t detect anymore platformio.
It seems that the install folder cannot be changed.
Nobody that can shed some light on this?
I guess you’ve found a solution by now, but for others surfing here:
After setting PLATFORMIO_CORE_DIR the install goes into the correct directory for me (on Ubuntu 22.04, for example):
python3 -c "$(wget -O - https://raw.githubusercontent.com/platformio/platformio/master/scripts/get-platformio.py)"
