Hi, I am trying to install the RTCZero library in platformio. I have configured the platformio.ini file
but the only storage option is global
Any advice?
Any advice?
It’s sufficient to declare the library in platformio.ini:
You can then build your project and the library will automatically be downloaed. There is no need to run anything else from the UI.
Hi, thanks for your answer!! By declaring the library in platformio.ini the library will be downloaded directly in the local project?
Yes, it goes into .pio/libdeps/yourconfig/yourlibrary` within your project folder.
