samarkh
January 12, 2024, 10:07am
1
I don’t understand how to make the t display s3 pro work with my code. If I use Lilygo’s own set up it works:
T-Display-S3-Pro GitHub
However, when I try to use the platformio + New Project I can’t work out how to add the board, even with Lilygo’s t-display-s3-pro.json file.
Any suggestions?
Yours Simon M
I don’t know what I did but using the following platformio.ini I got it to work:
[env:t-display-s3-presp-wrover-kit]
;boards_dir = board
board = t-display-s3-pro
platform = espressif32@6.3.0
board_build.partitions = huge_app.csv
; Enable UARDUINO_USB_CDC_ON_BOOT will start printing and wait for terminal access during startup
-DARDUINO_USB_CDC_ON_BOOT=1
; Enable UARDUINO_USB_CDC_ON_BOOT will turn off printing and will not block when using the battery
;-UARDUINO_USB_CDC_ON_BOOT
; TFT_eSPI warning elimination
-DDISABLE_ALL_LIBRARY_WARNINGS
; ! Using T-Display-Pro V1.0 , uncomment use V1.1 ,
; ! The difference between V1.0 and V1.1 is the backlight driver.
; -DUSING_DISPLAY_PRO_V1
lewisxhe/SensorLib @ ^0.1.4
lewisxhe/XPowersLib @ ^0.2.1
bxparks/AceButton @ ^1.10.1
Wire
SPI
hideakitai/MPU9250 @ ^0.4.8
electroniccats/MPU6050 @ ^1.0.0
wollewald/ICM20948_WE@^1.1.5 ; ICM20948
moononournation/GFX Library for Arduino @ ^1.3.7 ; Arduino_GFX_HelloWorld
moononournation/GFX Library for Arduino @ ^1.3.7 ; Arduino_GFX_PDQgraphicstest
moononournation/GFX Library for Arduino @ ^1.3.7 ; Arduino_GFX_LvglBenchmark
https://github.com/mmMicky/TouchLib.git ; Arduino_GFX_LvglBenchmark
;upload_port = COMxx
;monitor_port = COMxx
upload_speed = 1500000
This at least made the touch example work OK.
If someone could explain why please.
