I have the following really simple test code:
const char mybuffer[] PROGMEM = {
0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 0, 1, 2, 3, 4, 5, 6, 7, 8, 9,
... ~300kb ...
delay(4000);
Serial.println(strlen(mybuffer));
void loop() { }
without “mybuffer” the build process shows the following final data and program sizes for the esp32 and the esp8266 platform
Processing lolin32 (platform: espressif32@1.11.1; board: lolin32; framework: arduino)
DATA: [ ] 4.7% (used 15436 bytes from 327680 bytes)
PROGRAM: [== ] 16.5% (used 216509 bytes from 1310720 bytes)
Processing d1_mini (platform: espressif8266@2.3.2; board: d1_mini; framework: arduino)
DATA: [=== ] 32.8% (used 26876 bytes from 81920 bytes)
PROGRAM: [== ] 24.9% (used 260588 bytes from 1044464 bytes)
with “mybuffer” included
PROGRAM: [==== ] 39.4% (used 516593 bytes from 1310720 bytes)
PROGRAM: [===== ] 53.7% (used 560900 bytes from 1044464 bytes)
I do not understand why Inspect shows 100% RAM usage, with “mybuffer” included, for the esp32 while for the esp8266 it shows 33% only and everything seams to be ok.
