Hi, just wondering if the ‘inspect’ function can output to a text file of some sort? If it has a command line interface, or some sort of output functionality that I haven’t discovered, that would be great to know about ![:slight_smile: :slight_smile:](https://community.platformio.org/images/emoji/twitter/slight_smile.png?v=12)
Especially because whenever I click on a different button on PIO home, the inspect feature needs to be rerun which can be sometimes annoying.
Thanks!
There is pio check
on the CLI, and also as a shortcut in the command palette (Ctrl+Shift+P). But this does only static analysis, no size analysis.
Thanks Max, that is a shame that we can’t get a text based output. I may work on webscraping the output as the information is really great.
PIO check does support outputting in machine-readable JSON.
>pio check --help
Usage: pio check [OPTIONS]
Options:
-e, --environment TEXT
-d, --project-dir PATH
-c, --project-conf FILE
-f, --src-filters TEXT
--flags TEXT
--severity [low|medium|high]
-s, --silent
-v, --verbose
--json-output
--fail-on-defect [low|medium|high]
--skip-packages
-h, --help Show this message and exit.
