I ran “Inspect” on my Arduino Nano with the “Blink” test code. I got two “Defects”. At first I thought there were some errors in the memory hardware but when I clicked the defects tab, those were:
- The function ‘setup’ is never used.
- The function ‘loop’ is never used.
This is funny because the two functions were clearly used. Is this a bug?
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
delay(1000);
Seems like inspector doesn’t really see the cores/arduino/main.cpp file in which these functions are called. Also occurs for me from the commandline for the same code.
>pio check
Checking uno > cppcheck (platform: atmelavr; board: uno; framework: arduino)
src\main.cpp:11: [medium:warning] The function 'loop' is never used. [unusedFunction]
src\main.cpp:3: [low:style] The function 'setup' is never used. [unusedFunction]
========================================================================================== [PASSED] Took 2.61 seconds ==========================================================================================
Component HIGH MEDIUM LOW
src 0 1 1
Total 0 1 1
Environment Tool Status Duration
uno cppcheck PASSED 00:00:02.607
=============== 1 succeeded in 00:00:02.607 ===============
Please file a bug in https://github.com/platformio/platformio-core/issues.
It’s a known issue that was discussed and documented when the Project Inspection feature was added. Is a limitation of the fact that cppcheck doesn’t scan framework files (nor would you want it to - as any ‘errors’ there are not related to your code), so can’t reconcile that the setup() and loop() functions are actually used. Documented workaround is to put in comments that tell cppcheck to not check them for usage…
