Hi community!
For some reason, the “Inspect” button is greyed out when I pressed it and the inspection has run through. After fixing an issue uncovered here, I have to change its configuration by either deactivating “Inspect Memory” or “Check Code”. Next time I want to inspect, I have to re-activate one of those.
Is this expected behavior?
Thanks
Reproducable.
When I use “Inspect” with just “Check Code” on a project, it gives me all the results
and when I go back to “inspect”
It’s there as normal and I can click on it, but it doesn’t do anything.
Reported in issue Using the inspector then going back to it makes button unresponsive · Issue #2220 · platformio/platformio-home · GitHub, will be discussed there.
