wizio
June 15, 2021, 3:14pm
1
is there a possibility ( or idea for future ) INI file for library
example: github project “ABC”, suport X,Y,Z functions…
import to project_dir/lib as “LIB_ABC”
The INI file( or library PY script, in this folder “/lib/LIB_ABC” ) to be how to compile - defines, includes, sources from this “library/folder”
wizio:
Defines, includes and sources for a library are already controlled by the library.json file of the library.
This even supports extraScript
for custom Pytho logic if the static build flags etc. are not enough.
wizio
June 16, 2021, 4:47am
4
this extraScript is global/project or local/library - I am referring to local, library only
extraScript
is for the local library, not extra_scripts
for the project.
You can see an example here .
wizio
August 28, 2021, 6:54am
6
NICE - work… Thanks Max
need 2 files: library.json and script
“name”: “SomeLib”,
“version”: “0.0.0”,
“build”: {
"extraScript": "extra_script.py"
wizio
August 29, 2021, 4:44am
7
@maxgerhardt in extra_script is valid env.BuildLibrary (… filter ) ?
for the library in “this” folder
the question is: how to select the files for compilation
Yes, you can give it a source filter expression.
def BuildLibrary(env, variant_dir, src_dir, src_filter=None):
env.ProcessUnFlags(env.get("BUILD_UNFLAGS"))
return env.StaticLibrary(
env.subst(variant_dir), env.CollectBuildFiles(variant_dir, src_dir, src_filter)
The BuildSources
function has the same signature. Example with source filter:
# build system file (starts up clocks) and startup file (contains interrupt vector table)
system_file_dir = join(atmel_cmsis_dir, "CMSIS", "Device", "ATMEL", "sam3xa", "source")
system_file_dir_filter = "-<*> +<system_sam3xa.c> +<as_gcc/startup_sam3xa.c>"
env.BuildSources(join("$BUILD_DIR", "FrameworkCMSIS"), system_file_dir, src_filter=system_file_dir_filter)
Has the same format as src_filter
wizio
August 29, 2021, 3:16pm
9
library FOO ( include & src )
SRC folder is auto -scan for files and compiled library have temp-random-project file name
so… how to exclude files from SRC folder?
Oh I think in this case you just want to use a source filter.
Also see bottom of that chapter
https://docs.platformio.org/en/latest/librarymanager/config.html#extrascript
wizio
August 29, 2021, 8:10pm
11
THANKS MAX !!!
Work…
env.Replace(SRC_FILTER=src_filter_default)
