I have a script that builds/uploads the spiffs image if there is a change in the data directory (you can see it at end of Spiffs file system shortcut/auto upload - #7 by mchahn). It uses the command pio run -t uploadfs. The script was tested and worked well when run from the command line.
Then I added this script to my platformio.ini with extra_scripts = spiffs.py and now it it has a problem. Apparently my pre-build script triggers itself when using uploadfs. I get an infinite loop when running it from a command-line or running the build task. This is the output of the build task …
Processing esp32cam (platform: espressif32; board: esp32cam; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/esp32cam.html
PLATFORM: Espressif 32 (3.3.1) > AI Thinker ESP32-CAM
- framework-arduinoespressif32 3.10006.210326 (1.0.6)
- tool-esptoolpy 1.30100.210531 (3.1.0)
- toolchain-xtensa32 2.50200.97 (5.2.0)
Found 36 compatible libraries
|-- <WebSockets> 2.3.6+sha.46b2ae1
| |-- <WiFi> 1.0
| |-- <SPI> 1.0
| |-- <WiFiClientSecure> 1.0
| | |-- <WiFi> 1.0
|-- <WebServer> 1.0
| |-- <WiFi> 1.0
| |-- <FS> 1.0
|-- <WiFi> 1.0
|-- <SPIFFS> 1.0
| |-- <FS> 1.0
|-- <TelnetStream> 1.2.1+sha.cd18f6b
| |-- <WiFi> 1.0
|-- <ArduinoOTA> 1.0
| |-- <Update> 1.0
| |-- <WiFi> 1.0
| |-- <ESPmDNS> 1.0
| | |-- <WiFi> 1.0
|-- <SPI> 1.0
|-- <Preferences> 1.0
Building in debug mode
file updated in data directory -- building/uploading spiffs image
| |-- <WiFi> 1.0
| |-- <SPI> 1.0
| | |-- <WiFi> 1.0
|-- <WebServer> 1.0
| |-- <WiFi> 1.0
| |-- <FS> 1.0
|-- <WiFi> 1.0
|-- <SPIFFS> 1.0
| |-- <FS> 1.0
| |-- <WiFi> 1.0
|-- <ArduinoOTA> 1.0
| |-- <Update> 1.0
| |-- <WiFi> 1.0
| |-- <ESPmDNS> 1.0
| | |-- <WiFi> 1.0
|-- <SPI> 1.0
<ad infinitum>
How do I fix this? I just want pio to build/upload the spiffs image and do nothing else when using pio run -t uploadfs.
