Hi everyone,
Where can I open issues against build script of framework-arduinoststm32-maple
? It isn’t related to the framework per se, but the build script is contained inside framework folder.
Hi everyone,
I will post the issue here for now.
Here’s my platformio.ini
platform = ststm32
board = bluepill_f103c8
board_build.core = maple
upload_protocol = dfu
upload_port = anything
As you can see, I’m using Blue Pill board.
There is an inconsistency between build process and linker when I specify upload_protocol = dfu
. It resides in platformio-build-stm32f1.py
def get_vector_tab_addr(board, upload_protocol):
# Some special cases
boards_8005000 = (
"maple",
"maple_ret6",
"microduino32_flash",
"maple_mini_origin"
if any(b == board for b in boards_8005000):
return "0x8005000"
# depending on upload method
if upload_protocol == "dfu":
return "0x8002000"
elif upload_protocol == "hid":
return "0x8001000"
else:
# for other upload methods (including serial)
return "0x8000000"
This snippet sets interrupt vector table address to 0x8002000 when using DFU bootloader.
def get_linker_script(board, mcu, upload_protocol):
boards_with_boot_20 = (
"genericSTM32F103C",
"genericSTM32F103T",
"maple_mini_b20",
"hytiny_stm32f103t"
if any(b in board for b in boards_with_boot_20):
return "bootloader_20.ld"
elif board.startswith("genericSTM32F103R"):
return "bootloader.ld"
elif board.startswith("genericSTM32F103V"):
return "stm32f103veDFU.ld"
elif board.startswith("genericSTM32F103Z"):
return "stm32f103z_dfu.ld"
elif board == "maple_ret6":
return "stm32f103re-bootloader.ld"
# a rare case only one board
if board.startswith("genericSTM32F103C"):
return "hid_bootloader.ld"
else:
sys.stderr.write(
"%s doesn't support uploading using HID method\n" % board)
env.Exit(1)
else:
# Any other upload protocol
specific_scripts = (
"genericSTM32F103R",
"genericSTM32F103V",
"genericSTM32F103Z"
flash_scripts = (
"maple",
"mapleMini",
jtag_scripts = (
"nucleo_f103rb",
"genericSTM32F103CB",
"genericSTM32F103TB",
"disco_f100rb",
"hytiny_stm32f103t"
if any(b in board for b in specific_scripts):
return "%s.ld" % mcu[0:11]
elif any(b in board for b in flash_scripts):
return "flash.ld"
elif any(b in board for b in jtag_scripts):
return "jtag.ld"
elif board == "genericSTM32F103C8":
return "jtag_c8.ld"
elif board == "genericSTM32F103T8":
return "jtag_t8.ld"
return "flash.ld"
While this one sets linker script to flash.ld
which includes mem-flash.inc
which sets rom origin to 0x8005000.
But I have manually flashed DFU bootloader to Blue Pill and now I want to use DFU upload protocol. As a consequence, the program does not start. If I edit mem-flash.inc
manually and set rom origin to 0x8002000, the software works correctly.
I’ve found a temporary workaround: you need to supply custom linker script. Suppose it’s placed in src
folder with other source files and named flash.ld
, you need to add build_flags = -Wl,-T'"$PROJECT_DIR\src\flash.ld"'
to your platformio.ini
build environment section. The single quotes enclosing double quotes enclosing actual path is needed to escape possible spaces in path.
