When I don’t specify upload_port, there’s a warning that shows up with -v:
BeforeUpload(["upload"], ["build\esp32s3\firmware.bin"])
TimeoutError: Could not automatically find serial port for the `Unexpected Maker PROS3` board based on the declared HWIDs=['0X303A:80D0']
Auto-detected: COM15
and:
pio device list
COM15
Hardware ID: USB VID:PID=303A:1001 SER=F4:12:FA:42:0C:20 LOCATION=1-10:x.0
Description: USB Serial Device (COM15)
USBDeview shows VendorID “303a” and ProductID “1001”. The serial number shows up on the “USB JTAG/serial debug unit” but not the “USB Serial Device”, which has the drive letter COM15.
While it doesn’t seem to cause a problem directly (in my experience), this is a configuration error that may have side effects and which should be corrected.
Can you report that to Issues · platformio/platform-espressif32 · GitHub? Does it work locally when you modify the C:\Users\<user>\.platformio\platforms\espressif32\boards\um_pros3.json file in regards to the wrong PID/VID?
I’ve changed the local “um_pros3.json” file to the following:
"hwids": [
"0X303A",
"0X1001"
and get this warning:
TimeoutError: Could not automatically find serial port for the `Unexpected Maker PROS3` board based on the declared HWIDs=['0X303A:0X1001']
Yes, the lowercase “x” solved the problem and there is no warning when uploading without explicit upload_port when using the correct PID. I’ll pass this along in a GitHub issue. Thanks @maxgerhardt
