Hello. I built a baremetal project and now want to use an arduino stepper motor library so need to include arduino.h
I get squiggles in my header file when I try to do this:
and obviously, squiggles don’t compile:
Compiling .pio\build\ATmega4809\FrameworkArduino\USBCore.cpp.o
Compiling .pio\build\ATmega4809\FrameworkArduino\WInterrupts.cpp.o
In file included from C:\Users\Paul\.platformio\packages\framework-arduino-megaavr\cores\arduino\Arduino.h:140:0,
from C:\Users\Paul\.platformio\packages\framework-arduino-megaavr\cores\arduino\wiring_private.h:31,
from C:\Users\Paul\.platformio\packages\framework-arduino-megaavr\cores\arduino\WInterrupts.cpp:33:
C:\Users\Paul\.platformio\packages\framework-arduino-megaavr\cores\arduino\UART.h:28:10: fatal error: pins_arduino.h: No such file or directory
* Looking for pins_arduino.h dependency? Check our library registry!
My arduino IDE works fine, have I missed a path perhaps?
It depends on the selected variant & the existance of that variant folder in the core for that to work.
Assuming you are using board = ATmega4809, it has
And the core matchingly has the 48pin-standardfolder. PlatformIO has the MegaCoreX package as C:\Users\<user>\.platformio\packages\framework-arduino-megaavr-megacorex
However, as we can see from your log, the error comes from
When I use your above exact platformio.ini and a minimal code
void setup(){}
void loop(){}
it compiles for me.
>pio run
Processing ATmega4809 (board: ATmega4809; platform: atmelmegaavr; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelmegaavr/ATmega4809.html
PLATFORM: Atmel megaAVR (1.5.0) > ATmega4809
HARDWARE: ATMEGA4809 16MHz, 6KB RAM, 48KB Flash
- framework-arduino-megaavr-megacorex 1.0.9
- toolchain-atmelavr 2.70300.201015 (7.3.0)
Found 11 compatible libraries
Building in debug mode
Compiling .pio\build\ATmega4809\src\main.cpp.o
Compiling .pio\build\ATmega4809\FrameworkArduino\CDC.cpp.o
Compiling .pio\build\ATmega4809\FrameworkArduino\Tone.cpp.o
Compiling .pio\build\ATmega4809\FrameworkArduino\UART.cpp.o
Compiling .pio\build\ATmega4809\FrameworkArduino\UART0.cpp.o
Compiling .pio\build\ATmega4809\FrameworkArduino\UART1.cpp.o
Compiling .pio\build\ATmega4809\FrameworkArduino\UART2.cpp.o
Compiling .pio\build\ATmega4809\FrameworkArduino\UART3.cpp.o
Compiling .pio\build\ATmega4809\FrameworkArduino\UNO_compat.cpp.o
Compiling .pio\build\ATmega4809\FrameworkArduino\WInterrupts.c.o
Compiling .pio\build\ATmega4809\FrameworkArduino\WMath.cpp.o
Compiling .pio\build\ATmega4809\FrameworkArduino\abi.cpp.o
Compiling .pio\build\ATmega4809\FrameworkArduino\api\Common.cpp.o
Compiling .pio\build\ATmega4809\FrameworkArduino\api\IPAddress.cpp.o
Compiling .pio\build\ATmega4809\FrameworkArduino\api\PluggableUSB.cpp.o
Compiling .pio\build\ATmega4809\FrameworkArduino\api\Print.cpp.o
Compiling .pio\build\ATmega4809\FrameworkArduino\api\RingBuffer.cpp.o
Compiling .pio\build\ATmega4809\FrameworkArduino\api\Stream.cpp.o
Compiling .pio\build\ATmega4809\FrameworkArduino\api\String.cpp.o
Compiling .pio\build\ATmega4809\FrameworkArduino\hooks.c.o
Compiling .pio\build\ATmega4809\FrameworkArduino\main.cpp.o
Compiling .pio\build\ATmega4809\FrameworkArduino\new.cpp.o
Compiling .pio\build\ATmega4809\FrameworkArduino\wiring.c.o
Compiling .pio\build\ATmega4809\FrameworkArduino\wiring_analog.c.o
Compiling .pio\build\ATmega4809\FrameworkArduino\wiring_digital.c.o
Compiling .pio\build\ATmega4809\FrameworkArduino\wiring_pulse.S.o
Compiling .pio\build\ATmega4809\FrameworkArduino\wiring_pulse.c.o
Compiling .pio\build\ATmega4809\FrameworkArduino\wiring_shift.c.o
Archiving .pio\build\ATmega4809\libFrameworkArduino.a
Indexing .pio\build\ATmega4809\libFrameworkArduino.a
Linking .pio\build\ATmega4809\firmware.elf
Checking size .pio\build\ATmega4809\firmware.elf
RAM: [ ] 0.1% (used 4 bytes from 6144 bytes)
Flash: [ ] 1.2% (used 602 bytes from 49152 bytes)
Building .pio\build\ATmega4809\firmware.hex
============================================= [SUCCESS] Took 2.03 seconds =============================================
So you likely have corrupted files.
Remove the folder C:\Users\<user>\.platformio\packages\framework-arduino-megaavr-megacorex first and then rebuild the project.
You should also rather write #include <Arduino.h> in the correct uppercasing so that your code can compile on non-Windows machine which require you to use the correct spelling.
