I want to include the library StompClient
from github using lib_deps
. Because StompClient has a dependency to Websockets
my platformio.ini
looks the following:
links2004/WebSockets@^2.3.6
https://github.com/ukmaker/StompClient
The Problem is now that StompClient
doesn’t define any dependencies to WebSockets
using it’s library.properties
file and but includes it. When building I know obviosly get
.pio/libdeps/d1_mini/StompClient/src/StompClient.h:20:10: fatal error: WebsocketsClient.h: No such file or directory
Is there a way to fix that ?
Thanks
Have you tried all available lib_ldf_mode
Yes, I did try all options. But I think platformio
doesn’t recognize the dependency correctly since it’s not defined in the library.properties
file
Well if you’re on Linux one reason for the
is because the library authors misspelled the header here, as you can see in arduinoWebSockets/src at 2.0.3 · Links2004/arduinoWebSockets · GitHub it is WebSocketsClient.h
. So if I correct the librariy in regards to that (.pio/libdeps/nodemcuv2/StompClient/src/StompClient.h
), the dependency graph immediately gets fixed, but errors out later in compilation. I don’t think this 5 year old library is compatible with todays cores…
max@PC-LT-23-VM:~/temp/stomp$ pio run
Processing nodemcuv2 (platform: espressif8266; board: nodemcuv2; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/nodemcuv2.html
PLATFORM: Espressif 8266 (3.2.0) > NodeMCU 1.0 (ESP-12E Module)
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
- framework-arduinoespressif8266 3.30002.0 (3.0.2)
- tool-esptool 1.413.0 (4.13)
- tool-esptoolpy 1.30000.201119 (3.0.0)
- toolchain-xtensa 2.100300.210717 (10.3.0)
Found 37 compatible libraries
|-- <WebSockets> 2.3.6
| |-- <ESP8266WiFi> 1.0
| |-- <Ethernet> 2.0.0
| | |-- <SPI> 1.0
| |-- <SPI> 1.0
| |-- <Hash> 1.0
|-- <StompClient> 1.0.0+sha.81318ac
| | |-- <Ethernet> 2.0.0
| | | |-- <SPI> 1.0
| | |-- <SPI> 1.0
| | |-- <Hash> 1.0
Compiling .pio/build/nodemcuv2/src/main.cpp.o
Compiling .pio/build/nodemcuv2/lib61a/ESP8266WiFi/WiFiUdp.cpp.o
Compiling .pio/build/nodemcuv2/lib61a/ESP8266WiFi/enable_wifi_at_boot_time.cpp.o
Compiling .pio/build/nodemcuv2/libd7c/SPI/SPI.cpp.o
Compiling .pio/build/nodemcuv2/libef8/Ethernet/Dhcp.cpp.o
Compiling .pio/build/nodemcuv2/libef8/Ethernet/Dns.cpp.o
Compiling .pio/build/nodemcuv2/libef8/Ethernet/Ethernet.cpp.o
Compiling .pio/build/nodemcuv2/libef8/Ethernet/EthernetClient.cpp.o
Compiling .pio/build/nodemcuv2/libef8/Ethernet/EthernetServer.cpp.o
Compiling .pio/build/nodemcuv2/libef8/Ethernet/EthernetUdp.cpp.o
Compiling .pio/build/nodemcuv2/libef8/Ethernet/socket.cpp.o
Compiling .pio/build/nodemcuv2/libef8/Ethernet/utility/w5100.cpp.o
Compiling .pio/build/nodemcuv2/lib32b/Hash/Hash.cpp.o
Compiling .pio/build/nodemcuv2/lib76c/WebSockets/SocketIOclient.cpp.o
Compiling .pio/build/nodemcuv2/lib76c/WebSockets/WebSockets.cpp.o
Compiling .pio/build/nodemcuv2/lib76c/WebSockets/WebSocketsClient.cpp.o
In file included from .pio/libdeps/nodemcuv2/StompClient/src/StompClient.h:19,
from src/main.cpp:5:
.pio/libdeps/nodemcuv2/StompClient/src/StompCommandParser.h: In static member function 'static Stomp::StompCommand Stomp::StompCommandParser::parse(String)':
.pio/libdeps/nodemcuv2/StompClient/src/StompCommandParser.h:56:20: warning: comparison of integer expressions of different signedness: 'int' and 'unsigned int' [-Wsign-compare]
56 | while (start < headers.length()) {
In file included from src/main.cpp:5:
.pio/libdeps/nodemcuv2/StompClient/src/StompClient.h: In constructor 'Stomp::StompClient::StompClient(WebSocketsClient&, const char*, int, const char*, bool)':
.pio/libdeps/nodemcuv2/StompClient/src/StompClient.h:193:14: warning: 'Stomp::StompClient::_heartbeats' will be initialized after [-Wreorder]
193 | uint32_t _heartbeats;
.pio/libdeps/nodemcuv2/StompClient/src/StompClient.h:188:23: warning: 'void (* Stomp::StompClient::_connectHandler)(Stomp::StompCommand)' [-Wreorder]
188 | StompStateHandler _connectHandler;
.pio/libdeps/nodemcuv2/StompClient/src/StompClient.h:36:5: warning: when initialized here [-Wreorder]
36 | StompClient(
.pio/libdeps/nodemcuv2/StompClient/src/StompClient.h: In member function 'void Stomp::StompClient::beginSSL()':
.pio/libdeps/nodemcuv2/StompClient/src/StompClient.h:69:50: error: cannot convert 'String' to 'const char*'
69 | _wsClient.beginSSL(_host, _port, _socketUrl());
| String
In file included from src/main.cpp:4:
.pio/libdeps/nodemcuv2/WebSockets/src/WebSocketsClient.h:50:66: note: initializing argument 3 of 'void WebSocketsClient::beginSSL(const char*, uint16_t, const char*, const uint8_t*, const char*)'
50 | void beginSSL(const char * host, uint16_t port, const char * url = "/", const uint8_t * fingerprint = NULL, const char * protocol = "arduino");
.pio/libdeps/nodemcuv2/StompClient/src/StompClient.h: In member function 'void Stomp::StompClient::_handleWebSocketEvent(WStype_t, uint8_t*, size_t)':
.pio/libdeps/nodemcuv2/StompClient/src/StompClient.h:211:14: warning: enumeration value 'WStype_ERROR' not handled in switch [-Wswitch]
211 | switch (type) {
.pio/libdeps/nodemcuv2/StompClient/src/StompClient.h:211:14: warning: enumeration value 'WStype_FRAGMENT_TEXT_START' not handled in switch [-Wswitch]
.pio/libdeps/nodemcuv2/StompClient/src/StompClient.h:211:14: warning: enumeration value 'WStype_FRAGMENT_BIN_START' not handled in switch [-Wswitch]
.pio/libdeps/nodemcuv2/StompClient/src/StompClient.h:211:14: warning: enumeration value 'WStype_FRAGMENT' not handled in switch [-Wswitch]
.pio/libdeps/nodemcuv2/StompClient/src/StompClient.h:211:14: warning: enumeration value 'WStype_FRAGMENT_FIN' not handled in switch [-Wswitch]
.pio/libdeps/nodemcuv2/StompClient/src/StompClient.h:211:14: warning: enumeration value 'WStype_PING' not handled in switch [-Wswitch]
.pio/libdeps/nodemcuv2/StompClient/src/StompClient.h:211:14: warning: enumeration value 'WStype_PONG' not handled in switch [-Wswitch]
src/main.cpp: In function 'void setup()':
src/main.cpp:64:21: error: 'subscribe' was not declared in this scope
64 | stomper.onConnect(subscribe);
src/main.cpp:65:19: error: 'error' was not declared in this scope; did you mean 'perror'?
65 | stomper.onError(error);
| perror
Archiving .pio/build/nodemcuv2/libd7c/libSPI.a
Indexing .pio/build/nodemcuv2/libd7c/libSPI.a
Compiling .pio/build/nodemcuv2/lib76c/WebSockets/WebSocketsServer.cpp.o
*** [.pio/build/nodemcuv2/src/main.cpp.o] Error 1
===================================================== [FAILED] Took 2.48 seconds =====================================================
Okay, partly that is because I copied a .ino
file into .cpp
without doing the proper conversion, but it still leaves one compile failure in the library open…
| String
Ah yes, big thank you
Really didn’t see that. But you’re right, now there are different errors, I don’t want to fix. So I guess I won’t use that library…
If you use
[env:nodemcuv2]
platform = espressif8266
board = nodemcuv2
https://github.com/maxgerhardt/StompClient.git
with a src/main.cpp
of
#include <ESP8266WiFi.h>
#include <WebSocketsClient.h>
#include "StompClient.h"
void setup(){}
void loop(){}
Does it compile?
Yes it does. There are still some warnings, but I guess that’s fine. Thanks!
For reference, the converted variant of SpringStompButtons.ino
as a src/main.cpp
would be
* WiFi settings
const char *wlan_ssid = "--- Your wifi SSID ---";
const char *wlan_password = "--- Your wifi password";
* Stomp server settings
bool useWSS = true;
const char *ws_host = "--- Your Stomp server hostname ---";
const int ws_port = 4443;
const char *ws_baseurl = "/esp-websocket/"; // don't forget leading and trailing "/" !!!
// Confusingly, on a NodeMCU board these correspond to D1 and D2
#define BUTTON1 4
#define BUTTON2 5
// VARIABLES
WebSocketsClient webSocket;
Stomp::StompClient stomper(webSocket, ws_host, ws_port, ws_baseurl, true);
bool b1 = false;
bool b1_l = false;
bool b2 = false;
bool b2_l = false;
long b1_t = 0;
long b2_t = 0;
// Once the Stomp connection has been made, subscribe to a topic
void subscribe(Stomp::StompCommand cmd) {
Serial.println("Connected to STOMP broker");
void error(const Stomp::StompCommand cmd) {
Serial.println("ERROR: " + cmd.body);
void clickB1() { stomper.sendMessage("/esp/buttons", "{\\\"button\\\": 0}"); }
void clickB2() { stomper.sendMessage("/esp/buttons", "{\\\"button\\\": 1}"); }
* Read and debounce the buttons
void buttons() {
bool b = digitalRead(BUTTON1);
if (b != b1_l) {
b1_t = millis();
b1_l = b;
} else if ((millis() - b1_t) > 200) {
if (b1_l && !b1)
clickB1();
b1 = b1_l;
b = digitalRead(BUTTON2);
if (b != b2_l) {
b2_t = millis();
b2_l = b;
} else if ((millis() - b2_t) > 200) {
if (b2_l && !b2)
clickB2();
b2 = b2_l;
// Enable pullups on the GPIO pins the buttons are attached to
pinMode(BUTTON1, INPUT_PULLUP);
pinMode(BUTTON2, INPUT_PULLUP);
// setup serial
// flush it - ESP Serial seems to start with rubbish
Serial.println();
// connect to WiFi
Serial.println("Logging into WLAN: " + String(wlan_ssid));
Serial.print(" ...");
WiFi.begin(wlan_ssid, wlan_password);
delay(500);
Serial.print(".");
Serial.println(" success.");
Serial.print("IP: ");
// Start the StompClient
if (useWSS) {
stomper.beginSSL();
} else {
stomper.begin();
webSocket.loop();
buttons();
which also compiles for me. But I can’t make any statement on working during runtime.
