Here are my 2 problems:
#include errors detected. Please update your includePath. Squiggles are disabled for this translation unit (C:\Users\derek\Documents\PlatformIO\Projects\ArduinoUno R3 Detect I2C Address\src\main.cpp).
cannot open source file “avr/pgmspace.h” (dependency of “Arduino.h”)
Here is the output from Platformio: Build
* Executing task in folder ArduinoUno R3 Detect I2C Address: C:\Users\derek\.platformio\penv\Scripts\platformio.exe run
Processing uno (platform: atmelavr; board: uno; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/uno.html
PLATFORM: Atmel AVR (5.0.0) > Arduino Uno
DEBUG: Current (avr-stub) External (avr-stub, simavr)
- framework-arduino-avr @ 5.2.0
Found 6 compatible libraries
|-- i2cdetect @ 1.0.0
|-- Wire @ 1.0
Archiving .pio\build\uno\lib1af\libWire.a
Archiving .pio\build\uno\liba74\libi2cdetect.a
Archiving .pio\build\uno\libFrameworkArduinoVariant.a
Archiving .pio\build\uno\libFrameworkArduino.a
Indexing .pio\build\uno\libFrameworkArduinoVariant.a
Indexing .pio\build\uno\liba74\libi2cdetect.a
Indexing .pio\build\uno\lib1af\libWire.a
Indexing .pio\build\uno\libFrameworkArduino.a
Linking .pio\build\uno\firmware.elf
Checking size .pio\build\uno\firmware.elf
RAM: [== ] 23.7% (used 486 bytes from 2048 bytes)
Flash: [== ] 16.5% (used 5326 bytes from 32256 bytes)
==================================================== [SUCCESS] Took 2.34 seconds ====================================================
|-- Wire @ 1.0
==================================================== [SUCCESS] Took 0.80 seconds ====================================================
What have I broken that generates the Problems??
I uninstalled Platformio and deleted the ,platformio folder and did a clean build. everything looks OK but I get the issue of the 2 above Problems???
Please advise/ help…much appreciated as always
