Hello everyone, I’ve a new format and fresh installation of windows, vs and platformio.
Now I can’t build my project
In file included from .pio/libdeps/esp32doit-devkit-v1/ArduinoJson/src/ArduinoJson/Configuration.hpp:156:0,
from .pio/libdeps/esp32doit-devkit-v1/ArduinoJson/src/ArduinoJson.hpp:7,
from .pio/libdeps/esp32doit-devkit-v1/ArduinoJson/src/ArduinoJson.h:9,
from src/dome.cpp:1:
C:/Users/Tesla/.platformio/packages/framework-arduinoespressif32/cores/esp32/Arduino.h:142:21: fatal error: algorithm: No such file or directory
compilation terminated.
Compiling .pio\build\esp32doit-devkit-v1\lib632\AsyncTCP\AsyncTCP.cpp.o
In file included from .pio\libdeps\esp32doit-devkit-v1\AsyncTCP-esphome\src\AsyncTCP.cpp:22:0:
C:\Users\Tesla\.platformio\packages\framework-arduinoespressif32\cores\esp32/Arduino.h:142:21: fatal error: algorithm: No such file or directory
Compiling .pio\build\esp32doit-devkit-v1\libaea\FS\FS.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\libaea\FS\vfs_api.cpp.o
In file included from .pio\libdeps\esp32doit-devkit-v1\AsyncTCP\src\AsyncTCP.cpp:22:0:
In file included from C:\Users\Tesla\.platformio\packages\framework-arduinoespressif32\libraries\FS\src\FS.cpp:21:0:
C:\Users\Tesla\.platformio\packages\framework-arduinoespressif32\libraries\FS\src\FS.h:24:18: fatal error: memory: No such file or directory
In file included from C:\Users\Tesla\.platformio\packages\framework-arduinoespressif32\libraries\FS\src\vfs_api.h:18:0,
from C:\Users\Tesla\.platformio\packages\framework-arduinoespressif32\libraries\FS\src\vfs_api.cpp:15:
Compiling .pio\build\esp32doit-devkit-v1\lib8a7\WiFi\ETH.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib8a7\WiFi\WiFi.cpp.o
*** [.pio\build\esp32doit-devkit-v1\src\dome.cpp.o] Error 1
*** [.pio\build\esp32doit-devkit-v1\lib5ad\AsyncTCP-esphome\AsyncTCP.cpp.o] Error 1
*** [.pio\build\esp32doit-devkit-v1\libaea\FS\FS.cpp.o] Error 1
*** [.pio\build\esp32doit-devkit-v1\libaea\FS\vfs_api.cpp.o] Error 1
*** [.pio\build\esp32doit-devkit-v1\lib632\AsyncTCP\AsyncTCP.cpp.o] Error 1
In file included from C:\Users\Tesla\.platformio\packages\framework-arduinoespressif32\libraries\WiFi\src\WiFiSTA.h:28:0,
from C:\Users\Tesla\.platformio\packages\framework-arduinoespressif32\libraries\WiFi\src\WiFi.h:32,
from C:\Users\Tesla\.platformio\packages\framework-arduinoespressif32\libraries\WiFi\src\ETH.h:24,
from C:\Users\Tesla\.platformio\packages\framework-arduinoespressif32\libraries\WiFi\src\ETH.cpp:21:
C:\Users\Tesla\.platformio\packages\framework-arduinoespressif32\libraries\WiFi\src\WiFiGeneric.h:28:22: fatal error: functional: No such file or directory
*** [.pio\build\esp32doit-devkit-v1\lib8a7\WiFi\ETH.cpp.o] Error 1
from C:\Users\Tesla\.platformio\packages\framework-arduinoespressif32\libraries\WiFi\src\WiFi.cpp:24:
*** [.pio\build\esp32doit-devkit-v1\lib8a7\WiFi\WiFi.cpp.o] Error 1
My .platformio.ini
[env:esp32doit-devkit-v1]
board = esp32doit-devkit-v1
ottowinter/ESPAsyncWebServer-esphome@~1.2.7
me-no-dev/ESP Async WebServer@~1.2.3
alanswx/ESPAsyncWiFiManager@~0.24
bblanchon/ArduinoJson@^6.18.5
lorol/LittleFS_esp32@^1.0.6
It seems like he don’t find arduino.h how can I install it??
Why both these libraries?
I can’t reproduce your issue with a clean
#include <ArduinoJson.h>
DynamicJsonDocument doc(1024);
String input =
"{\"sensor\":\"gps\",\"time\":1351824120,\"data\":[48.756080,2.302038]}";
deserializeJson(doc, input);
JsonObject obj = doc.as<JsonObject>();
Serial.println(input);
void loop() {}
Processing esp32doit-devkit-v1 (platform: espressif32; board: esp32doit-devkit-v1; framework: arduino)
PLATFORM: Espressif 32 (3.4.0) > DOIT ESP32 DEVKIT V1
- framework-arduinoespressif32 3.10006.210326 (1.0.6)
- tool-esptoolpy 1.30100.210531 (3.1.0)
- toolchain-xtensa32 2.50200.97 (5.2.0)
Found 29 compatible libraries
|-- <ArduinoJson> 6.18.5
Compiling .pio\build\esp32doit-devkit-v1\src\main.cpp.o
Generating partitions .pio\build\esp32doit-devkit-v1\partitions.bin
Archiving .pio\build\esp32doit-devkit-v1\libFrameworkArduinoVariant.a
Indexing .pio\build\esp32doit-devkit-v1\libFrameworkArduinoVariant.a
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\Esp.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\FunctionalInterrupt.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\HardwareSerial.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\IPAddress.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\IPv6Address.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\MD5Builder.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\Print.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\Stream.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\StreamString.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\WMath.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\WString.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\base64.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\cbuf.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-adc.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-bt.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-cpu.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-dac.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-gpio.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-i2c.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-ledc.c.o
src\main.cpp: In function 'void setup()':
src\main.cpp:10:14: warning: variable 'obj' set but not used [-Wunused-but-set-variable]
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-log.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-matrix.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-misc.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-psram.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-rmt.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-sigmadelta.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-spi.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-time.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-timer.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-touch.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-uart.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\libb64\cdecode.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\libb64\cencode.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\main.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\stdlib_noniso.c.o
C:\Users\Max\.platformio\packages\framework-arduinoespressif32\cores\esp32\esp32-hal-spi.c: In function 'spiTransferBytesNL':
C:\Users\Max\.platformio\packages\framework-arduinoespressif32\cores\esp32\esp32-hal-spi.c:922:39: warning: initialization from incompatible pointer type [-Wincompatible-pointer-types]
uint8_t * last_out8 = &result[c_longs-1];
C:\Users\Max\.platformio\packages\framework-arduinoespressif32\cores\esp32\esp32-hal-spi.c:923:40: warning: initialization from incompatible pointer type [-Wincompatible-pointer-types]
uint8_t * last_data8 = &last_data;
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\wiring_pulse.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\wiring_shift.c.o
Archiving .pio\build\esp32doit-devkit-v1\libFrameworkArduino.a
Indexing .pio\build\esp32doit-devkit-v1\libFrameworkArduino.a
Linking .pio\build\esp32doit-devkit-v1\firmware.elf
Retrieving maximum program size .pio\build\esp32doit-devkit-v1\firmware.elf
Checking size .pio\build\esp32doit-devkit-v1\firmware.elf
RAM: [ ] 4.1% (used 13312 bytes from 327680 bytes)
Flash: [== ] 15.7% (used 206366 bytes from 1310720 bytes)
Building .pio\build\esp32doit-devkit-v1\firmware.bin
esptool.py v3.1
Merged 1 ELF section
=============== [SUCCESS] Took 9.14 seconds ===============
As far as I can see, the Arduino.h
file is being found and included. The error messages are coming from an inability to find other files that are #include
d by Arduino.h
. I suspect the “missing” files are specifically for C++ I suspect, given the names – algorithm
etc.
Algorithm
, memory
etc are, as far as I recall, part of the C++ Standard Library. Is your toolchain correctly installed? I know it should be downloaded and installed automatically when you compile the first project using that toolchain, but you never know!
Cheers,
Norm.
Sincerly i don’t know, I format the pc, installed python, Vs code and platformio.
Only Microsoft c++ plugins are working, have you any idea what/where i can check?
In the last instance where we discussed this issue (Impossible to build project No such File or Directory · Issue #4149 · platformio/platformio-core · GitHub) I suspected that you had an antivirus active which corrupted the toolchain download.
Can you disable all active antivirus software, remove the folder C:\Users\Tesla\.platformio\packages\toolchain-xtensa32
and C:\Users\Tesla\.platformio\.cache
and rebuild the project?
Someone saw me this test but If i remove the folder it told me una le tu run toolchain-xtensa32 command, but I didn’t remove the cache folder, in 10minutes I’ll try
I have no antivirus, maybe Windows defender
If you want this is the repo:
The platformio.ini
references a local folder of yours, which is not good for reproducability.
If I also remove the double ESP Async Webserver dependency and add in the ArduinoJSON dependency with
me-no-dev/ESP Async WebServer@^1.2.3
alanswx/ESPAsyncWiFiManager@^0.24
The project compiles perfectly.
Found 34 compatible libraries
|-- <ESP Async WebServer> 1.2.3
| |-- <AsyncTCP> 1.1.1
| |-- <FS> 1.0
| |-- <WiFi> 1.0
|-- <ESPAsyncWiFiManager> 0.24.0
| |-- <DNSServer> 1.1.0
| | |-- <WiFi> 1.0
| | |-- <AsyncTCP> 1.1.1
| | |-- <FS> 1.0
| | |-- <WiFi> 1.0
| |-- <WiFi> 1.0
|-- <ESP32 Async UDP> 1.0.0
|-- <HTTPClient> 1.2
| |-- <WiFi> 1.0
| |-- <WiFiClientSecure> 1.0
| | |-- <WiFi> 1.0
|-- <SPIFFS> 1.0
| |-- <FS> 1.0
|-- <WiFi> 1.0
Compiling .pio\build\esp32doit-devkit-v1\src\dome.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib31e\AsyncTCP\AsyncTCP.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib4ed\FS\FS.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib4ed\FS\vfs_api.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib586\WiFi\ETH.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib586\WiFi\WiFi.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib586\WiFi\WiFiAP.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib586\WiFi\WiFiClient.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib586\WiFi\WiFiGeneric.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib586\WiFi\WiFiMulti.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib586\WiFi\WiFiSTA.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib586\WiFi\WiFiScan.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib586\WiFi\WiFiServer.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib586\WiFi\WiFiUdp.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\libb99\ESP Async WebServer\AsyncEventSource.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\libb99\ESP Async WebServer\AsyncWebSocket.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\libb99\ESP Async WebServer\SPIFFSEditor.cpp.o
Archiving .pio\build\esp32doit-devkit-v1\lib4ed\libFS.a
Compiling .pio\build\esp32doit-devkit-v1\libb99\ESP Async WebServer\WebAuthentication.cpp.o
Indexing .pio\build\esp32doit-devkit-v1\lib4ed\libFS.a
Compiling .pio\build\esp32doit-devkit-v1\libb99\ESP Async WebServer\WebHandlers.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\libb99\ESP Async WebServer\WebRequest.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\libb99\ESP Async WebServer\WebResponses.cpp.o
Archiving .pio\build\esp32doit-devkit-v1\lib31e\libAsyncTCP.a
Compiling .pio\build\esp32doit-devkit-v1\libb99\ESP Async WebServer\WebServer.cpp.o
Indexing .pio\build\esp32doit-devkit-v1\lib31e\libAsyncTCP.a
Compiling .pio\build\esp32doit-devkit-v1\lib8df\DNSServer\DNSServer.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib703\ESPAsyncWiFiManager\ESPAsyncWiFiManager.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\libdb9\AsyncUDP\AsyncUDP.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib17a\WiFiClientSecure\WiFiClientSecure.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib17a\WiFiClientSecure\ssl_client.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib529\HTTPClient\HTTPClient.cpp.o
Archiving .pio\build\esp32doit-devkit-v1\lib586\libWiFi.a
Indexing .pio\build\esp32doit-devkit-v1\lib586\libWiFi.a
Compiling .pio\build\esp32doit-devkit-v1\lib1d5\SPIFFS\SPIFFS.cpp.o
Archiving .pio\build\esp32doit-devkit-v1\lib8df\libDNSServer.a
Indexing .pio\build\esp32doit-devkit-v1\lib8df\libDNSServer.a
.pio\libdeps\esp32doit-devkit-v1\ESPAsyncWiFiManager\ESPAsyncWiFiManager.cpp: In member function 'void AsyncWiFiManager::copySSIDInfo(wifi_ssid_count_t)':
.pio\libdeps\esp32doit-devkit-v1\ESPAsyncWiFiManager\ESPAsyncWiFiManager.cpp:316:12: warning: unused variable 'res' [-Wunused-variable]
bool res=WiFi.getNetworkInfo(i, wifiSSIDs[i].SSID, wifiSSIDs[i].encryptionType, wifiSSIDs[i].RSSI, wifiSSIDs[i].BSSID, wifiSSIDs[i].channel);
Archiving .pio\build\esp32doit-devkit-v1\libdb9\libAsyncUDP.a
Indexing .pio\build\esp32doit-devkit-v1\libdb9\libAsyncUDP.a
Archiving .pio\build\esp32doit-devkit-v1\lib17a\libWiFiClientSecure.a
Indexing .pio\build\esp32doit-devkit-v1\lib17a\libWiFiClientSecure.a
Archiving .pio\build\esp32doit-devkit-v1\lib1d5\libSPIFFS.a
Indexing .pio\build\esp32doit-devkit-v1\lib1d5\libSPIFFS.a
Archiving .pio\build\esp32doit-devkit-v1\lib529\libHTTPClient.a
Indexing .pio\build\esp32doit-devkit-v1\lib529\libHTTPClient.a
Archiving .pio\build\esp32doit-devkit-v1\lib703\libESPAsyncWiFiManager.a
Indexing .pio\build\esp32doit-devkit-v1\lib703\libESPAsyncWiFiManager.a
Archiving .pio\build\esp32doit-devkit-v1\libb99\libESP Async WebServer.a
Indexing .pio\build\esp32doit-devkit-v1\libb99\libESP Async WebServer.a
RAM: [= ] 13.6% (used 44468 bytes from 327680 bytes)
Flash: [======== ] 81.3% (used 1066258 bytes from 1310720 bytes)
esptool.py v3.1
============== [SUCCESS] Took 20.84 seconds ==============
very strange, now i’ve deleted the toolchain folder and I didn’t get error and it don’t download it…
what version of python I need for platformio??
See docs. I’m peronstally running 3.8.6.
So it worked? PlatformIO automatically re-downloads the toolchain if it detects that it was deleted, that is normal…
No is ok, I delete all .cache folder and I delete all inside package, he download all the things and tadan, now is build succesfully!!
thank you so much!!
