Thank you very much for the hint. But the output doesn’t help me either. The last library is the etl, which I also included in the MiniTest project. So here’s the expression. Can you spot anything that isn’t consistent?
PS D:\sources\elektronik_heizung\Heizung\sw\heizung_app> pio test -vvv
Collected 1 tests (test_desktop)
Processing test_desktop in native environment
Building...
LDF Modes: Finder ~ chain, Compatibility ~ off
Found 15 compatible libraries
|-- lvgl @ 8.3.0-dev+sha.6ad52a7 (License: MIT, URI: git+https://github.com/lvgl/lvgl, Path: D:\sources\elektronik_heizung\Heizung\sw\heizung_app\.pio\libdeps\native\lvgl)
|-- ArduinoJson @ 6.19.4 (License: Unknown, Path: D:\sources\elektronik_heizung\Heizung\sw\heizung_app\.pio\libdeps\native\ArduinoJson)
|-- Embedded Template Library @ 20.28.0+sha.752d9ad (License: MIT, URI: git+https://github.com/ETLCPP/etl, Path: D:\sources\elektronik_heizung\Heizung\sw\heizung_app\.pio\libdeps\native\Embedded Template Library)
|-- aktor (License: Unknown, Path: D:\sources\elektronik_heizung\Heizung\sw\heizung_app\lib\aktor)
| |-- db (License: Unknown, Path: D:\sources\elektronik_heizung\Heizung\sw\heizung_app\lib\db)
| | |-- globals (License: Unknown, Path: D:\sources\elektronik_heizung\Heizung\sw\heizung_app\lib\globals)
|-- http (License: Unknown, Path: D:\sources\elektronik_heizung\Heizung\sw\heizung_app\lib\http)
|-- persisting (License: Unknown, Path: D:\sources\elektronik_heizung\Heizung\sw\heizung_app\lib\persisting)
|-- sensADC (License: Unknown, Path: D:\sources\elektronik_heizung\Heizung\sw\heizung_app\lib\sensADC)
|-- sensDigi (License: Unknown, Path: D:\sources\elektronik_heizung\Heizung\sw\heizung_app\lib\sensDigi)
|-- history (License: Unknown, Path: D:\sources\elektronik_heizung\Heizung\sw\heizung_app\lib\history)
|-- settings (License: Unknown, Path: D:\sources\elektronik_heizung\Heizung\sw\heizung_app\lib\settings)
|-- googletest @ 1.11.0 (License: BSD-3-Clause, Path: D:\sources\elektronik_heizung\Heizung\sw\heizung_app\.pio\libdeps\native\googletest)
|-- screenLayers (License: Unknown, Path: D:\sources\elektronik_heizung\Heizung\sw\heizung_app\lib\screenLayers)
Building in test mode
*** [.pio\build\native\program.exe] Implicit dependency `.pio\build\native\None' not found, needed by target `.pio\build\native\program.exe'.
Building stage has failed, see errors above. Use `pio test --verbose` option to enable verbose output.
