Hi!
I have an ini
file that I’m using for test codes from topics in Arduino forum and the file has a long list of libraries under lib_deps
The problem is:
When I have a new code to compile I have to comment out all unused libraries under lib_deps
How I can make dependency scanner
look only for libraries included on sketch?
Thanks in advance.
Best regards.
Hi!
Thanks for your answer!
I’m not sure if I did in the right way but I think it doesn’t worked.
I did in this way:
[common]
upload_port = /dev/ttyUSB0
monitor_port = /dev/ttyUSB0
lib_ldf_mode = chain+
build_flags = -D
lib_deps = ; Many libraries
[env:mega2560]
board = megaatmega2560
upload_port = ${common.upload_port}
monitor_speed = ${common.monitor_speed}
monitor_port = ${common.monitor_port}
lib_ldf_mode = ${common.lib_ldf_mode}
build_flags = ${common.build_flags}
${common.lib_deps}
After install all libraries in lib_deps
the compiling message was:
- framework-arduino-avr @ 5.1.0
LDF Modes: Finder ~ chain+, Compatibility ~ soft
Found 50 compatible libraries
Dependency Graph ; long list
Then this errors even with only bounce2
library included on code.
Best regards.
Hi!
There’s any other suggestion for this problem?
Best regards.
