Is it possible to define IF conditions for different boards?
I wanna share the same code for different boards (esp32 & esp8266). These boards need different WiFi libraries. How can I SWITCH them by an IF condition? Is this possible?
I saw, that I can add build params like -D ESP32
But is there something which is set already by PlatformIO?
Yes, as you can see in e.g. here each board has specific macros. But PIO also defines macros like
-DPLATFORMIO=40000 -DARDUINO_Heltec_WIFI_Kit_32 -DESP32 -DESP_PLATFORM -DF_CPU=240000000L -DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\" -DARDUINO=10805 -DARDUINO_ARCH_ESP32 -DARDUINO_VARIANT=\"heltec_wifi_kit_32\" "-DARDUINO_BOARD=\"Heltec WIFI Kit 32\""
(for a heltec esp32 board)
So you could e.g. use
#ifdef ARDUINO_ARCH_ESP32
//include ESP32 specific libs
#elif defined(ARDUINO_ARCH_ESP8266)
//include esp8266 specific libs
#else
You can do a verbose compilation run with pio run -v
Also take a look at Redirecting...
