Idf_tools.py installation failed
I get this failure when I try to compile a program. It was compiling before but now I get this error. Any help would be greatly appreciated
Help the members of this forum to help you by providing more details:
  • Which system are you using?
  • What is the content of your platformio.ini file?
  • Which version of the platform is installed on your system?
  • Any other information that might be important…
Without this information, everyone can only guess.
So something must have changed. What has changed in the meantime?
Sorry for the lack of info. Just frustrated I guess.
I’m on MacOS 12.7. VSCode 1.103. PlatformIO core 6.1.18, home 3.4.4.
I wish I knew what I changed.
I deleted VSCode and did a reinstall.
I went to the Expressf ESP32 page and installed all the prerequisites ccache 4.11, ninja 1.13, cmake 4.1, Python 3.12.4
I still get idf_tools.py installation failed. If I try to make a new project, it fails and here is the error I get.
PIO Core Call Error: "The following files/directories have been created in /Users/macmini/Documents/PlatformIO/Projects/blink\ninclude - Put project header files here\nlib - Put project specific (private) libraries here\nsrc - Put project source files here\nplatformio.ini - Project Configuration File\nResolving esp32doit-devkit-v1 dependencies…\nAlready up-to-date.\nUpdating metadata for the vscode IDE…\n\n\nidf_tools.py installation failed\nidf_tools.py installation failed\nUserSideException: Processing esp32doit-devkit-v1 (platform: espressif32; board: esp32doit-devkit-v1; framework: arduino)\n--------------------------------------------------------------------------------\nidf_tools.py installation failed\nidf_tools.py installation failed\nVerbose mode can be enabled via -v, --verbose option\nidf_tools.py installation failed\nPYTHONEXE updated to penv environment: /Users/macmini/.platformio/penv/bin/python\nPermissionError: [Errno 13] Permission denied: ‘/Users/macmini/.platformio/penv/bin/uv’:\n File "/Users/macmini/.platformio/penv/lib/python3.12/site-packages/platformio/builder/main.py", line 173:\n env.SConscript("$BUILD_SCRIPT")\n File "/Users/macmini/.platformio/packages/tool-scons/scons-local-4.8.1/SCons/Script/SConscript.py", line 620:\n return _SConscript(self.fs, *files, **subst_kw)\n File "/Users/macmini/.platformio/packages/tool-scons/scons-local-4.8.1/SCons/Script/SConscript.py", line 280:\n exec(compile(scriptdata, scriptname, ‘exec’), call_stack[-1].globals)\n File "/Users/macmini/.platformio/platforms/espressif32@src-88f34194123b4b05ff6ef6b8e68c7f60/builder/main.py", line 434:\n install_python_deps()\n File "/Users/macmini/.platformio/platforms/espressif32@src-88f34194123b4b05ff6ef6b8e68c7f60/builder/main.py", line 267:\n result = subprocess.run(\n File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/subprocess.py", line 548:\n with Popen(*popenargs, **kwargs) as process:\n File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/subprocess.py", line 1026:\n self._execute_child(args, executable, preexec_fn, close_fds,\n File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/subprocess.py", line 1955:\n raise child_exception_type(errno_num, err_msg, err_filename)\n========================== [FAILED] Took 1.82 seconds
I seem to be in a hole and I just keep digging deeper. Very frustrating.
  1. Close VSCode
  2. Delete the entire /Users/macmini/.platformio/ folder (make backups of anything custom-modified in there if needed – if not, safe to nuke.)
  3. Restart VSCode and wait for reinit
Max
Thanks so much. That did it. Everything is working now.
Thanks again
