Ideaspark Devboards and devkits support
I’m waiting for the following devkit from Ideaspark:
Could you add their boards/kits as supported devkit please? or if there should already be support for this particular one can you tell me which board should I use to have a full support for above one?
Kind Regards,
Piguła Horacy
grafik
Well. But if if it’s the same as https://www.amazon.com/Instrument-Integrated-Temperature-Humidity-Atmospheric/dp/B0CZHHTM1F there will be PDF documentation with it that’ll tell you exactly how to configure it with the Arduino IDE, and then https://docs.platformio.org/en/latest/platforms/espressif32.html tells you what boards PlatformIO supports or how you can configure the generic “ESP32 Dev Board” definition to your likings to exactly match the Arduino IDE configuration (for example for flash size, etc.)
