First of all, great product, and kudos for everyone that contributed.
I’m running the platform ide on Arch linux with the latest versions of node (v6.4.0), electron (v1.3.3) and IDE version 1.4.0
So far so good.
Still if I create a simple Arduino program, and I press Upload, then a command line window opens, the upload process starts and concludes sucessufully. Still the window has a counter in seconds that doesn’t stop even after the upload sucess.
From this point I can’t upload anything again on the IDE, without closing it and opening it again.
yep, I am. This issue was the only one I couldn’t solve since it was deep inside nodejs base code on the children_process.
The aur atom-editor-bin uses much older self contained chrome, electron and nodejs versions, without clashing with the main packages, so it works out of the box with platformio ide
OOOOOOhhhh my goodness.
Thank you for the tip with atom-editor-bin.
It finally works again.
I even once got a debug session from Ivan. Nearly everthing got fixed. But i think it still missed a bug, compiling did not stop.
Anyways i had to reinstall and was lost again, where to start or stop changing with the nodejs stuff.
Finally i can use it on Linux again. Thank you thx1011
